Printed Circuit Board - Team Camaro Tech
post #1 of 6 (permalink) Old May 5th, 09, 11:29 AM Thread Starter
Hey guys, one of the traces on my PCB has come loose from the PCB where the plug from the harness plugs in. I need to re-attach it. What should I use for adhesive?
68 Coupe, 350, M20 frame off restoration (a work in progress).
ironhorse78247 is offline
post #2 of 6 (permalink) Old May 5th, 09, 12:03 PM
Guess
HwyStarJoe's Avatar
Re: Printed Circuit Board
I would think that any good glue would suffice.
I wouldn't use something like model glue (Testers) because it melts plastic. A couple light dabs of SuperGlue in strategic spots should work.
You could even try 'painting' it down with clear nail polish.
Shoot that circuit with an Ohm meter just to make sure the trace didn't separate internally.
HwyStarJoe is offline
post #3 of 6 (permalink) Old May 5th, 09, 12:13 PM
68driver57's Avatar
dont use superglue. It has a corrosive effect that can cause you problems later. Use a two part epoxy, that's how we fix them for aircraft use.
68 coupe
matching 327
95 coupe (bone stock)
68driver57 is offline
post #4 of 6 (permalink) Old May 5th, 09, 12:42 PM
Vintage 68's Avatar
Thumbs up Re: Printed Circuit Board
^^^ X2
1968 Convertible
Some trucks
Vintage 68 is offline
post #5 of 6 (permalink) Old May 10th, 09, 06:54 PM Thread Starter
Problem solved. Used epoxy and it works great. Thanks guys.
post #6 of 6 (permalink) Old Mar 21st, 12, 10:49 PM
Joseph
Got a name brand of the epoxy to use or just any type of epoxy? Does it have to or should it be clear?
cam1967rsss is offline
