Interior/Courtesy light problem - Team Camaro Tech
post #1 of 6 (permalink) Old May 5th, 09, 10:03 PM Thread Starter
Tim
I know I'm on a Camaro forum but here is my problem..I have a 67 Firebird and while driving it tonight I noticed the interior lights would flash on when I turned to the right. The work normal when you open the doors or use the switch to manually turn them on. When the car is sitting still and you turn to the right they don't flash on. Any ideas??
Original wiring harness..
Any help appreciated before I get pissed and rewire the whole car..
226gpd is offline
post #2 of 6 (permalink) Old May 6th, 09, 12:48 AM
Steiner
Re: Interior/Courtesy light problem
There should be a wire (maybe white) running from the left door switch over to the right door switch. It is the ground for the light circuit and maybe it has a raw place on it that is rubbing on the steering column. See if you can find it under the dash.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 6 (permalink) Old May 6th, 09, 09:50 AM Thread Starter
Tim
I'm pretty sure I found the problem..The passenger side light under the glove box..The socket had come loose form the mount bracket and when I would turn it would shift over and ground out causing the lights to come on...I'll know for sure after a few drives..Thanks for the help..
226gpd is offline
post #4 of 6 (permalink) Old May 7th, 09, 07:08 PM
Deja Vu...didn't I read about this somewhere else.
dnult is offline
post #5 of 6 (permalink) Old May 7th, 09, 07:14 PM
Glad to see that you saw the light, Tim.
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
post #6 of 6 (permalink) Old May 8th, 09, 06:38 AM
1st 67 SS/RS's Avatar
Good job. At least your lights work! Still working on mine. Previous owner hacked up my wiring harness. The vert gets a little dark at night.
67 Vert RS/SS 350 4 SP
1st 67 SS/RS is offline
