69 BB...Yellow Wire from Starter Live? - Team Camaro Tech
post #1 of 12 (permalink) Old May 11th, 09, 07:11 PM Thread Starter
JB
I replaced my harness in my 69 big block (was small block). The wire from the starter to coil is always live with the battery hooked up. The resistor wire from the fuse block is also live, even though I separated them hoping to use it for my HEI. The yellow wire to wiper motor is live too... should the 'R' be live all the time? If so, why does it go to the coil?
69RSMAN is offline
post #2 of 12 (permalink) Old May 11th, 09, 07:26 PM
Brandon
Re: 69 BB...Yellow Wire from Starter Live?
Sounds like an issue at the keyswitch. Neither the Yellow from starter or the wire to the resistor should be hot at all times. Once your car was started you'd never be able to shut it off. Yellow wire should die out after switch is turned from start to run. If not, with a regular dizzy you'd melt the points in very short order as a normal dizzy only runs on 6+volts.
Recheck the connections on the start switch through the fuse block.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 12 (permalink) Old May 12th, 09, 05:22 AM Thread Starter
JB
I thought so. Fortunately, I've been running from fenderside for engine break in and ran a separate wire from battery. Since I'm now trying to get it to a normal state of running, I noticed the issue. I found some melted wires going to the console harness later last night and think I've got a wire backfeeding to the fuse block and to the whole system.. Even the acc tang on the fuse block is live with key off. Will dig into it more tonight.. Thanks
69RSMAN is offline
post #4 of 12 (permalink) Old May 12th, 09, 05:26 AM
The yellow wire doesn't go 'dead' in the run position, it is always at the same potential as the positive lead to the coil.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #5 of 12 (permalink) Old May 12th, 09, 07:15 PM Thread Starter
JB
Well, the problem was I wired a used one-wire alternator up, but plugged in the 2 prong connector too (following directions from another blog). All wires from it are live all the time, so it back fed into my system to the fuse block. I pulled the 2 prong connector out and all works perfectly now.
What does the 'R' on the starter mean? Regulator? though it goes to the coil?
69RSMAN is offline
post #6 of 12 (permalink) Old May 12th, 09, 08:06 PM
R stands for relay. It is connected to a relay contact that puts 12v directly to the coil when the solenoid is engaged.
post #7 of 12 (permalink) Old May 12th, 09, 08:36 PM
Brandon
sorry to hear about your harness, glad you got it straightend out.
Nantooch is offline
post #8 of 12 (permalink) Old May 13th, 09, 07:21 PM Thread Starter
JB
Thanks... Me too!
Does the 'R' output only come live when solenoid is enaged? In other words, I can't connect that wire to my HEI becuase it won't stay live when the car runs...sound right? I connected to an acc tang on the fuse block.
69RSMAN is offline
post #9 of 12 (permalink) Old May 13th, 09, 07:51 PM
that's correct, it's only powered in start, not run
post #10 of 12 (permalink) Old May 13th, 09, 09:25 PM
...I connected to an acc tang on the fuse block.
What did you connect to ACC power?
dnult is offline
post #11 of 12 (permalink) Old May 13th, 09, 10:06 PM
ACC is not powered in START position, so you may have to move to IGN source during start.
post #12 of 12 (permalink) Old May 14th, 09, 06:13 PM Thread Starter
JB
You're correct. I had it on Acc and it didn't start so I moved it to Ign (lowest tang). It worked after that.
69RSMAN is offline
