Electrical gremlins -69 Camaro - Team Camaro Tech
post #1 of 9 (permalink) Old May 14th, 09, 04:37 PM Thread Starter
I have been working on a car that was restored in 89 and has been sitting since....only 250 miles in 20 years. I am having the following issues....
1. Amp gauge is fine when car is idling. Turn on running lights and the amperage is fine. Turn on headlights and amperage drops. Ideas why? Maybe regulator or faulty alternator?
2. Signals are not working. I am thinking a ground somewhere for this problem since the dash was out to replace the tach that was sticking.
g356gear is offline
post #2 of 9 (permalink) Old May 14th, 09, 05:13 PM
Re: Electrical gremlins -69 Camaro
Without knowing other facts on the car, I'd say its normal because the alternator may only be a 37 amp capacity.
On the case next to the adjustment bolt, is the amperage of the alt. If equipped with a 37 amp, headlamps on, ammeter will show a discharge at engine idle due to alt only being controlled by the regulator, again, normal indication.
The true test would be to measure battery voltage at time of charging with engine running. Normally, with no accessories on and in 10 -15 minutes of run time, 13.2 to 13.8 volts would be normal. Add a load, and what the alt can't supply, battery will assist. As battery warms up, less charge voltage is needed.
Also, drive belt tightness comes into play. Loose belt, lower output.
One change you can make to improve the present situation is to replace the mechanical voltage regulator with an electronic reg, strictly plug & play, a Wells P/N VR715 and transfer the ground wire. Disconnect the battery cable, ground is preferred, and wire brush the connections to the horn relay below the regulator to remove any high resistance. Also, move the ground connection from the alternator bracket to the block itself and clean the battery posts and clamps.
If turn signals outside don't work, but emergency flashers do, then you might unplug/plug the steering column connector and maybe giggle the turn signal handle. The copper contacts inside might have corroded over time. Or the flasher itself is bad located next to the steering column under the dash. Again, only if emergency flashers work and turn signals don't.
If flashers don't work, then might be power problem or a ground problem at each socket in each corner of the car. Wire brush again. The hierarchy of the rear lights is emergency over turn signals over brake lights.
Hope this helps.
post #3 of 9 (permalink) Old May 16th, 09, 11:05 AM Thread Starter
Thanks Everett. I am going to work on it this weekend and go through your recomendations. I will update as I progress. Thanks again!
g356gear is offline
post #4 of 9 (permalink) Old May 21st, 09, 06:53 AM
Just quickly reading your post and was thinking about my boss who had a late model Corvette, he was restoring and his car would almost shut off when he turned on his lights. He couldnt figure out why. After trial and error, someone asked him if he changed his coil. I think he said he had a blaster, the black one, and when he changed it out, it worked perfectly. Might want to try that, if the car has been sitting around.
Talikaluvr is offline
post #5 of 9 (permalink) Old May 28th, 09, 09:52 PM Thread Starter
Hope this helps.
Well, I swapped out the original console gauges for a new OER set and everything there works fine now.
Only problem left is that I have hazard lights but no signals at all. I went through the wiring diagrams and found that there are 2 dash grounds...1 on the LH side dashboard and the other on the dashboard brace. I think I found the LH ground (see pic) but I can't find the other ground. There is one loose black wire (ground?) under the center dash speaker. Where does this one attach??
If the flasher is bad where can I find a new one?? It looks like I have one of the signal dash bulbs burned out as well. Any ideas where to get new dash bulbs? Thanks for the help.
g356gear is offline
post #6 of 9 (permalink) Old May 29th, 09, 04:01 AM
I would suspect the black wire by the speaker be ground, maybe to the ducting screw?
Flashers and bulbs can be bought at your local parts store, NAPA.
Directional indicators are 194
Turn signal flasher is a 512, but get one for trailer use/heavy duty. The reason being is the standard flasher relies on having the correct load, read current rating of all the lights being used, to flash - one bulb burns out, no flash. A heavy duty/trailer use has a definite duty cycle and can handle up to six lights - lights will always flash even if one bulb is out.
post #7 of 9 (permalink) Old May 29th, 09, 02:46 PM Thread Starter
Picked up a new hvy duty signal flasher today and a bunch of 194 bulbs plus a full fuse assortment to replace everything with new. For $20 why mess around. We will see if that helps anything.
g356gear is offline
post #8 of 9 (permalink) Old May 30th, 09, 12:15 PM Thread Starter
replaced the flasher and all the fuses and everything seems to be working fine now. Thanks for all the help.
g356gear is offline
post #9 of 9 (permalink) Old May 30th, 09, 03:16 PM
You're welcome.
