temperature sending unit - Team Camaro Tech
post #1 of 17 (permalink) Old May 19th, 09, 09:22 AM Thread Starter
Ben
Tried this yesterday in engine section,no replies,so thought Id try here.
Late model 350 with 3/8" temp holes in heads,want to retain original 1/2" sending unit. I dont have any 1/2" holes.Can I use the hole on top of the water pump instead of changing out the thermostat outlet neck ??Would that give me an inaccurate reading? Thanks in advance for any help
Ben
Big Ben
1967 Camaro
1980 Z/28 all original
original owner
2011 2SS/RS Camaro 6speed/manual
BigBen is offline
post #2 of 17 (permalink) Old May 19th, 09, 09:58 AM
Matt
Re: temperature sending unit
No holes in the intake? That's where my is mounted...
Matt
zlek131 is offline
post #3 of 17 (permalink) Old May 19th, 09, 12:45 PM Thread Starter
Ben
There is a hole in the intake ,butt that is where a heater hose goes. Ben
Big Ben
1967 Camaro
original owner
BigBen is offline
post #4 of 17 (permalink) Old May 19th, 09, 12:58 PM
foreverlookin's Avatar
Ben what intake are you using?
foreverlookin is offline
post #5 of 17 (permalink) Old May 19th, 09, 02:08 PM Thread Starter
Ben
The intake is a GM replacement manifold to replace a throttle body fuel injection with a four barrel carb.
Ben
Big Ben
1967 Camaro
original owner
BigBen is offline
post #6 of 17 (permalink) Old May 19th, 09, 11:40 PM
Steiner
Go to Napa and get a brass 1/2" to 3/8" reducer.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 17 (permalink) Old May 20th, 09, 06:27 AM Thread Starter
Ben
Where am I going to put it,will the top of the water pump be accurate?
Big Ben
1967 Camaro
original owner
BigBen is offline
post #8 of 17 (permalink) Old May 20th, 09, 06:41 AM Thread Starter
Ben
I want to use a 1/2" hole to keep the original sending unit,has only 1 wire and is for a gauge. I would use the 3/8" hole in the side of the head if i could find one with 1 wire and for a gauge.
Big Ben
1967 Camaro
original owner
BigBen is offline
post #9 of 17 (permalink) Old May 20th, 09, 07:15 AM
Charlie
Drill a hole in the GM intake. It's only cast aluminum. It drills very easily. Put thick grease on the drill bit so the shavings won't fall into the motor. Then take a 1/2"NPT tap and tap the hole. The hole on the water pump will not work. Unless you don't want heat in the winter. That hose supplies your heater core and the hose on the intake is the return. The sending unit needs to be in direct contact with coolant so if you use a reducer, make sure it doesn't sit the sending unit back so far that it doesn't make contact with coolant flow. Drilling the intake is so easy. I can't believe it doesn't have a hole already.
67CamaroRS/SS is offline
post #10 of 17 (permalink) Old May 20th, 09, 07:28 AM Thread Starter
Ben
It does have a hole,but that is where one heater hose goes and the other one goes to the water pump.
Big Ben
1967 Camaro
original owner
BigBen is offline
post #11 of 17 (permalink) Old May 20th, 09, 08:18 AM
You might look into opening the 3/8 hole to 1/2 as using an adapter will not place the sending unit into the coolant flow and get an erroneous reading, ie, not hot enough indicated. Plus the 1/2 inch won't fit in a 3/8 adapter.
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
post #12 of 17 (permalink) Old May 20th, 09, 09:30 AM Thread Starter
Ben
Maybe I could put a tee fitting at on the intake where the heater hose is at??
Big Ben
1967 Camaro
original owner
BigBen is offline
post #13 of 17 (permalink) Old May 20th, 09, 01:52 PM
The sending ubit needs to be in the coolant flow to give the correct temperature reading. Out of flow, out of temp zone, too cool will be indicated.
post #14 of 17 (permalink) Old May 20th, 09, 02:14 PM
Got a picture of the top of the intake?
post #15 of 17 (permalink) Old May 21st, 09, 07:39 AM
Charlie
The intake should have a hole on the front passenger side for the heater hose and another hole either next to it or on the other side front to the side of the stat housing. If not, then just drill a hole. It's only cast aluminum. It's easy to drill. Do not use a "T" on the heater hose and do not use a reducer. The sending unit needs to be in DIRECT contact with the coolant flow. The reducer sets the sending unit back too far to have the coolant flowing DIRECTLY over the sender. It will give you a false reading. Each cylinder head has a hole in it. The drivers side head is between #1 and #3 cylinders and the passenger side head is between #6 and #8 cylinders. If you drill the intake, make sure you put a thick grease on the drill bit so it will collect the shavings. Trust me, it's easy as pie to drill the intake. Get yourself a 1/2"NPT tap. It has to be a NPT tap because all NPT holes are tapered. They get narrower the further they go down. On NPT threads and fittings, it's the threads that do the sealing.
