68 RS Headlight Wiring Info Needed!!! - Team Camaro Tech
post #1 of 11 (permalink) Old May 19th, 09, 01:31 PM Thread Starter
eric
I was repairing some wiring on a customers 68 RS Camaro and without thinking I cut out all of his RS headlight wiring. I have not been able to find the diagram for the mod that was used. It has a standard relay(5 terminal) and a small black 8 terminal relay with limit switches. I have searched over and over and everything I have found is a different design. This is all I have left on this car before I can finish. If anyone could help it would be great.
Thanks,
Eric
eldogg is offline
post #2 of 11 (permalink) Old May 19th, 09, 07:08 PM
Re: 68 RS Headlight Wiring Info Needed!!!
does it look like this?
if so there is information in the electrical sticky named electrify your RS.
TTFN
Mat
SSCARGO
Mat Klemp is offline
post #3 of 11 (permalink) Old May 20th, 09, 07:12 AM Thread Starter
eric
No it doesn't. It uses to vertical style motors and no module what so ever. The motors work great. I can't seem to fiure out how to wire in the limit or stop switches. I could post some pictures if needed.
Thanks,
Eric
eldogg is offline
post #4 of 11 (permalink) Old May 20th, 09, 07:35 AM
click's Avatar
Just to clarify it seems someone installed elec. motors in a 68 system. The original 68 RS cars had vacuum controlled doors.
Any way to find out what elec. conversion brand is there now?
click is offline
post #5 of 11 (permalink) Old May 20th, 09, 07:50 AM Thread Starter
eric
I spoke to the owner of the car. He is clueless. Could he have used 67 stuff? The limit switches look kinda OEM. Sorry I sound soo stupid. I can figure out most anything but this has me stumped.
Thanks,
Eric
eldogg is offline
post #6 of 11 (permalink) Old May 20th, 09, 09:47 AM
Fred
Eric, we need pictures. You're new here. Welcome!
128.79mph 1.428 60'
Fred Ficarra is offline
post #7 of 11 (permalink) Old May 20th, 09, 11:58 AM Thread Starter
eric
I will post some pics when I get back to the shop. I've been a member for a long time. just have not posted. I guess you would call me a lurker!!!
eldogg is offline
post #8 of 11 (permalink) Old May 20th, 09, 12:35 PM Thread Starter
eric
I have some pics of the limit switch and of what relays I cut out. Let me know if you need something else.
http://www.flickr.com/photos/[email protected]/3548764753/
http://www.flickr.com/photos/[email protected]/3548764751/
Thanks,
Eric
eldogg is offline
post #9 of 11 (permalink) Old May 20th, 09, 03:10 PM
Fred
Eric, I'll be lurking here too. My system is vacuum. But you're in very safe hands.
128.79mph 1.428 60'
post #10 of 11 (permalink) Old May 20th, 09, 04:34 PM
Some random thoughts.
"68 used a vacuum system, so the motors were added.
The motors could be one of the following options that I know of, there may be more.
Original '67 motors.
Reproduction '67 motors.
Retro-electric motors.
DSE motors, but I believe these mount below the fender.
Some options:
Try to piece together the wires you cut out ?
If they are original '67 then you can wire it like the original '67 but you will need the relays and possibly other limit switches.
If they are reproduction '67 motors then you could use a firebird module, but the arms will need to be fixed to the shaft.
I'm not sure about the retrolectric, but you can ask them.
TTFN
Mat
SSCARGO
post #11 of 11 (permalink) Old May 20th, 09, 07:25 PM Thread Starter
eric
Guys thanks alot for all the help but the owners brother-in-law built the setup that is on the car. It uses 67 motors with some home brewed wiring. I am suppose to get a diagram tommorow from the brother-in-law. Thanks again for all of the help.
Eric
eldogg is offline
