Electric Choke Positive Connection - Correct Placement? - Team Camaro Tech
post #1 of 4 (permalink) Old May 22nd, 09, 06:19 AM Thread Starter
Chad
I have a 69, with a fairly stock 350 with an Edelbrock Carb, that has an electric choke. I recently put on a new wiring harness, and the one hook up that I have yet to connect is the positive connection for the electric choke.
Where should I connect or splice this? What is the correct way or most appropriate way? I have seen guys splice it into their alt., wiper motor, etc
Thanks for any help.
OUTarHeel
OUTarHeel is offline
post #2 of 4 (permalink) Old May 22nd, 09, 07:51 AM
Dan
Re: Electric Choke Positive Connection - Correct Placement?
I connected mine to the +wire on the coil. I read here that you need to make sure that you have 12v at that wire when the engine is running. It's working fine for me.
Dan
1968 RS - Black
408 w/ Muncie 4 speed & 12 bolt rear
Deluxe Houndstooth Interior
Dropped 2" with TeamIII Mini-Lites
Click for Picture:
funbnme is offline
post #3 of 4 (permalink) Old May 22nd, 09, 08:20 AM
ADAM
any 12v source that on with ignition
68 ss clone sbc350 tko600 chassisworks , 69 LSX454 bbc (in progress jakes), 70 rs 454 mp500efi
AJSZR2326 is offline
post #4 of 4 (permalink) Old May 22nd, 09, 10:02 AM
Steiner
Mine is tapped at the wiper motor. If yours is like mine, there are two plugs on the passenger side of the wiper motor against the firewall. One is a single, one is a double. The single is the switched 12V.
'69 Camaro
500hp/538lbft
Steiner is offline
