Tic-toc-tach wiring (repo) - Team Camaro Tech
 1Likes
  • 1 Post By sammann
post #1 of 6 (permalink) Old May 25th, 09, 11:34 PM Thread Starter
Larry
larryh56's Avatar
I looked for this info for a couple of days and couldn't get a clear picture so I thought i would post my wiring. I have a Painless harness and purchased an aftermarket tic-toc-tach for my '68 because it looks good and is also cheaper then changing both the speedo and tach. I also purchased a new printed circuit board. There were no wiring instructions with the tach. So I hooked the purple tach wire to the isolated post in the 4 o'clock position and the other end to the negative side of the coil. Result - clock only works when the key is on and the tach registers about 1K depending on the accessories that are on, lol. Time to figure out what’s what.
The first picture shows the green temp gauge wire that was basically passed through the pin location where the tach wire for the coil should be. I cut it and attached the purple wire from the negative coil post. The water temp gauge wire is joined back together and crimped, soldered and insulated. The stud at the 12 o'clock position behind the tach is where the coil should be attached and where that pin connects to. The last picture (sorry its fuzzy) shows the correct wiring with the stud at the 4 o'clock position wired to a constant 12V source for the clock (the instrament cluster is upside down). The pink wire that is cut in the pictures is for the fuel gauge which has been re-routed to the console fuel gauge.
ID:	10402   Click image for larger version
ID:	10404   Click image for larger version
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #2 of 6 (permalink) Old Sep 20th, 13, 05:16 PM
dennis
Re: Tic-toc-tach wiring (repo)
Larry, where did you connect the Red wire (clock) for the 12v constant source?
If it was already there, then I guess I'll need to fish it out. I'm changing to a quartz clock and my original clock didn't have a wire connected to it.
Thank you for your consideration
Regards
RS68SS is offline
post #3 of 6 (permalink) Old Sep 20th, 13, 08:40 PM
69-Pace's Avatar
Clock goes to the spade marked BAT.
It is to the right of the fuse marked
CLK LTR CTSY
CLK = Clock
LTR = Lighter
CTSY for the Courtesy lights.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 6 (permalink) Old Sep 20th, 13, 11:52 PM Thread Starter
Larry
larryh56's Avatar
Any constant 12V source will work. Brian's suggestion will work fine.
Samuel Adams
larryh56 is offline
post #5 of 6 (permalink) Old Sep 21st, 13, 08:23 AM
dennis
Thank you both I really appreciate it
RS68SS is offline
post #6 of 6 (permalink) Old Aug 27th, 18, 12:45 PM
Probationer
Thanks this saved my butt
Smithtown NY
69-Pace likes this.
sammann is offline
