Msd - Team Camaro Tech
post #1 of 6 (permalink) Old May 28th, 09, 02:35 PM Thread Starter
Msd
Does anyone know if I can just remove the cap and wires and replace with a factory style cap and wires color black?(Want a factory look)
1969 Camaro Convertible 427 5 Speed
provfirescott is offline
post #2 of 6 (permalink) Old May 28th, 09, 02:45 PM
Andrew
Andrew69's Avatar
Re: Msd
I doubt it, but others will know for sure. But you could remove the cap and paint it black. I believe Walmart sells paint for painting plastics.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 6 (permalink) Old May 28th, 09, 03:09 PM
Re: Msd
As far as I know the standard factory cap fits Never tried it though.
Msd also make a black cap #MSD-84333 and I usually buy a roll of MSD 8.5 Black and make my own wires.
rodent4 is offline
post #4 of 6 (permalink) Old May 28th, 09, 03:19 PM
Dave M
Barefoot Dave's Avatar
Re: Msd
MSD 8437 is a very dark red color and will work with your distributor. It's designed for the original socket style plug wires. I use them on my cars because they look pretty close to original.
Dave Miller
2014 Z/28
2015 ZL1
Barefoot Dave is offline
post #5 of 6 (permalink) Old May 28th, 09, 08:47 PM
Re: Msd
Stock black socket style cap with the window in it will work, no issues.
Regards,
Milton
The Devil's advocate is offline
post #6 of 6 (permalink) Old May 29th, 09, 11:42 AM
Re: Msd
I haven't seen too many caps with HEI terminals for a small body distributor that were not some shade of red. Just beware that some of the suggestions above are non HEI style caps. I'm not sure if you'd have any problems using a non HEI cap on an electronic ignition. You'd definately have to change those wires to match the cap though.
dnult is offline
