1968 camaro turn signal problem - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 15th, 09, 06:45 PM Thread Starter
knightmoose's Avatar
I have an all origibnal everything 68 camaro, my left turn signal when you turn it on stays solid trangle green and doesnt blink... I thought it was the bulb so i replace both the front and rear bulbs and get the same result..
with no turn signal on when i turn on the head lights the left turn signal illuminates solid green, i just cant seem to find out where the short is actually at? im certain its on the left side lol becaus eevertything works on the right side, i just dont know? any suggestions? maybe a bad ground or something?
it about helping others
knightmoose is offline
post #2 of 8 (permalink) Old Aug 16th, 09, 03:58 PM
Re: 1968 camaro turn signal problem
Up front, follow the ground wire back to the radiator support and clean the terminals and area.
At the rear, make sure the sockets are making a good connection in the light fixture as well as a good connection of the bulbs in their sockets.
Of course, you've changed the bulbs with the same number both front & rear.
You might even pull out the socket, remove the bulb, and push out the center pins and lengthen the spring alittle. Wire brushing things might not hurt either.
post #3 of 8 (permalink) Old Aug 18th, 09, 07:54 PM Thread Starter
hmm the wire at the radiator was broken i tried to reground agian and i still have the same problem, somewehere their is a serious short
post #4 of 8 (permalink) Old Aug 18th, 09, 09:02 PM
Do the emergency flashers work at all four corners?
The flashers use the same bulb filament as the brake/turn signal lights.
You might substitute a heavy duty flasher as the h/d flasher times itself to flick on/off and does not depend on bulb resistance to flash as a standard flasher does. More commonly known as a trailer light flasher, P/N 552 as opposed to a 512?
With the turn signal indicator coming on with headlights on signifies a faulty ground path, hence the t/s indicator coming on or a miswire between the headlights and turn signals, maybe a parking light wire, brown(?), misplaced?
post #5 of 8 (permalink) Old Oct 16th, 12, 12:38 PM
rich
had same problem found back side of d/s plug (for bulb) to be all messed up the short is in the socket or harness up front. could be turn signal indicator but rare to find
rs salvati is offline
post #6 of 8 (permalink) Old Oct 16th, 12, 05:42 PM
Welcome, Rich. Glad to have you here.
post #7 of 8 (permalink) Old Oct 17th, 12, 04:46 PM
USN1969SS's Avatar
I had the same issue in my 69, took the turn signal and idiot lights out from under the dash, cleaned all the bulb connections with a file and problem fixed. As the others have mentioned, you have a bad connection somewhere. A dirty connection can cause an increase in impedance and although the lamps work, can cause a problem.
1969, 350 "Beast", M20, Nothing Fancy, Nothing Pretty, But Sure is Fun!
USN1969SS is offline
post #8 of 8 (permalink) Old Oct 17th, 12, 05:40 PM
Other than the last four posts (incl this one) this thread was three years old...
Eric
Eric Kammerer is offline
