help need wiring diagram for center console 69 - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 19th, 09, 05:03 PM Thread Starter
Help I want to get this thing right... Dose anyone have the wiring dirgram for a center console in a 69 camaro?? this console was added on not original. I have 7 wires coming out orange/2-black/green/red or pink/brown/gray. Please anyone... Thanks
jjam is offline
post #2 of 7 (permalink) Old Aug 19th, 09, 05:47 PM
Re: help need wiring diagram for center console 69
There are wiring diagrams in the electrical basics sticky post. You'll need to pm me for the password to open them.
Non gauge console wires should be:
Violet and violet w/white stripe (big 12 guage wires) nuetral safety switch
pink 12 volt power to backup light switch
dark green from backup light switch out to backup lights
orange power from clock courtesy lighter fuse going back to the courtesy light
White switched side of couresy light circuit.
Gray from gauge illumination circuit (gauges fuse) to illuminate the shift quadrant.
I don't recall a ground, other than one in the harness that screws to the forward bracket that holds the console to the floor, that is a small black wire.
Edit by Jim. NOTE:
The wiring above is for an automatic floor shift non gauge car.
The OP told me in PM that his car is column shift and with gauges.
A VERY unusual car for sure!
post #3 of 7 (permalink) Old Aug 19th, 09, 06:06 PM
Vic
this is for the shifter
Vic
1969 Camaro SS
Camaro1969 is offline
post #4 of 7 (permalink) Old Aug 19th, 09, 06:29 PM Thread Starter
I have gauges in my center console and it is a 4-sp with only 7 wires coming out orange/2-black/green/red or pink/brown/gray. Where do these go?
jjam is offline
post #5 of 7 (permalink) Old Aug 20th, 09, 11:11 AM Thread Starter
OK, think I got it. Orange - Floor console Light / Green - Water / Pink - Gauges Fuze / Brown - Fuel Sender / Black x's 2 - Amp / Gray - unk? maybe oil? Anyone is this correct
jjam is offline
post #6 of 7 (permalink) Old Aug 20th, 09, 05:00 PM
That looks pretty close.
A gauge / console / column shift car (per pm), eh? That is unusual, and certainly changes my post above.
The orange does go to the courtesy light in the back of the console, there should be a white wire for that too.
The green will be water.
The 2 blacks are the ammeter.
Brown is fuel
The pink one is 12 volt switched power, from the gauges fuse, it provides power to the water and fuel gauges.
The gray one is illumination, it goes to the lamps in all the gauges.
The oil gauge is mechanical, there is a plastic tube that goes to the engine, no wire.
post #7 of 7 (permalink) Old Aug 21st, 09, 04:54 AM Thread Starter
Thanks, that Gray is the one that I was stumped on. Thanks again JimM. Also your sticky notes, help allot.
jjam is offline
