Mystery Draw on Battery - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 21st, 09, 01:05 PM Thread Starter
I have noticed my battery seems a little tired when starting, but its a brand new battery. I put a tester on and found a 3/4 Amp constant draw on the battery, even with all of the fuses pulled - even the flaser. Any ideas on where this could be coming from would be huge.
68 RS/SS 350 4Spd
blumarln is offline
post #2 of 6 (permalink) Old Aug 21st, 09, 02:28 PM
Lee
Re: Mystery Draw on Battery
68 RS/SS 350 4Spd
I just had the same problem....for me it was the external Voltage regulator (69 Camaro) the part was still avail. from A/C Delco...$100can.
canX11 is offline
post #3 of 6 (permalink) Old Aug 21st, 09, 04:30 PM
Yep, ext regulator or alternator - unplug the BAT terminal to make sure the alt is good.
And you're sure any Convenience lighting installed, if equipped, is off?
Glovebox light, engine bay light, trunk light.
You might look/unbolt the junction block next to the battery as the back side is open and I have seen rust build up and become a resistance path to ground.
post #4 of 6 (permalink) Old Aug 21st, 09, 04:52 PM
"Tri-Tip"
Gary L's Avatar
Could be the diodes in the alt. as well.
Gary L is offline
post #5 of 6 (permalink) Old Aug 21st, 09, 07:26 PM
Lee
Yup, forgot to mention...i rebuilt the Alt. as well...just to be safe and cleaned up all the Grounds.
canX11 is offline
post #6 of 6 (permalink) Old Aug 22nd, 09, 11:50 PM
So your diode tree checks good then? That's usually what fails when an alternator starts leaking current. Also, if you assemble the electrical parts incorrectly you can wind up with a ground short or leak.
dnult is offline
