signal help? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 21st, 09, 02:09 PM Thread Starter
Trev
madcarson's Avatar
signal help?
rewired with hwy 22 kit,left sigs work but right doesn't ? dash bulb goes solid but no flash,put test light to it and bulb goes out ??
69 Resto MOD
383
madcarson is offline
post #2 of 4 (permalink) Old Aug 21st, 09, 04:21 PM
Re: signal help?
When you put the test light onto the bulb wire and light goes out, the test lamp has the least resistance, therefore, the dsh light goes out.
I'd look at the ground connections both front & rear and make sure the right bulb filament is being lit. Emergency flashers over rule other lights, do they work?
post #3 of 4 (permalink) Old Aug 22nd, 09, 04:55 PM Thread Starter
Trev
madcarson's Avatar
Re: signal help?
hazards only work on driv.side also! No pass side! Flashers both work in dash lights
69 Resto MOD
383
post #4 of 4 (permalink) Old Aug 23rd, 09, 07:35 AM
Re: signal help?
Okay, you'll have to trace out at the column connector, GReen wire is power for E/F from the fusebox. Then out of e/f sw to Light blue and dark blue wires.
At this point, the dash indicators are tapped from here, so if corner bulbs are on, then those bulbs are getting constant power rather than flasher power.
Brake light switch good & circuit works?
