just did CS130 Alternator upgrade, now factory tach having fits - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 26th, 09, 10:58 AM Thread Starter
happen to anyone else? MSD6AL ignition hooked up to factory tach with no problems for past 2 years then i upgrade alternator (works great by the way) but now tach is bouncing all over, reading incorrectly, and still functions after unplugging the tach wire out of the msd box.
69 Camaro 406sbc ALL MOTOR 1.43
Full weight street car driven to track on pumpgas
camaromatt is offline
post #2 of 4 (permalink) Old Aug 26th, 09, 09:12 PM
Steiner
Re: just did CS130 Alternator upgrade, now factory tach having fits
The last time I had a jumpy tach, it wound up that I had bumped the connection while working on something else. I went back and soldered the tach signal line and it fixed it.
'69 Camaro
500hp/538lbft
Steiner is offline
post #3 of 4 (permalink) Old Aug 27th, 09, 06:02 AM
Art
Check the connection as mentioned above, if that doesn't take care of it use a DVOM and measure AC voltage output in the charging system. A bad rectifier bridge can allow AC voltage to leak into the system, giving you a small offset that wreaks havoc with modern electronics.
Artie
67 Camaro
99 T/A Daily Driver
Previous:
67 Camaro Traded for my 98
68 Camaro Street/Strip
98 Camaro Race car Best ET 9.08 @ 152 1.18 60'
Dyno sheets don't win races, see you at the track
SRGN is offline
post #4 of 4 (permalink) Old Aug 27th, 09, 07:29 PM Thread Starter
thanks guys, turns out it was the new but bad alternator.........drained battery, swapped it out and all my electrical woes are gone.
