Wiper switch problem? 1968 - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 26th, 09, 06:59 PM Thread Starter
Patrick
Hey guys. My wipers only move when you push the knob in which I think is washer mode. Then they seem to work just fine. Of course I rathe not keep hitting the knob all day.
I am new to this old car. How does the washer work, when it actually does?
Is this a motor issue or a switch issue?
1968 Convertible L92 VVT project, Hotchkiss lowering front & rear.
68problemchild is offline
post #2 of 2 (permalink) Old Aug 27th, 09, 11:21 AM
Dan
Re: Wiper switch problem? 1968
It could be the switch not making a good ground on the dash. check and clean area (sand to clean metal and use some no-ox or dialectric grease)behind dash where switch seats there should be a special star washer that helps make a good ground when unit is tightened then try again and see if it works
68 camaro RS 327/275 THM350 4 wheel disc brake 8.5 10 bolt 3.42 daily driver
icpop is offline
