Burning ignition - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 27th, 09, 12:14 AM Thread Starter
Ron
Angry Burning ignition
I have just run into a problem with the electric system on my 68 Camaro.
I was driving today and stopped and turned of the ignition. After about 5 minutes I was back and when I turned on the ignition to start the engine there was nothing. I then noticed smoke coming from under the hood. The smoke was coming from the horn relay area. When I checked one of the red wires going to the relay it was hot and had melted the insulation. My first thought was that the horn relay shorted out, so I replaced the relay with no results. When I try to start the engine there was nothing and the red wire gets hot when trying to start (engage the starter) the engine. My cars voltmeter does not read any any voltage when I turn the ignition to the start position, however in the accessory mode I have full voltage. The engine in the car is a complete 350 GM turn key. The alternator has a internal regulator and as such does use an external regulator. I have had this engine in the car for over two years with no problems what so ever. The wiring diagram does not provide a clear picture of the red wire connections, where it comes from etc.
Any ideas??
Viking11 is offline
post #2 of 6 (permalink) Old Aug 27th, 09, 03:41 AM
Re: Burning ignition
Sounds like your starter solenoid is frozen in the "ON" position, or your starter is jammed, which caused a huge current draw.
Hanging on the Maine Coast...moved back North
1969 RS/SS, 383, 4spd, 373s, 12bolt, FatMat, Vintage Air - Super Red, and it's my first Camaro.
Engine pics
Radiator pics
Build album
Lobstah is offline
post #3 of 6 (permalink) Old Aug 27th, 09, 08:09 AM
Lex
Lexlas's Avatar
I had a similair issue but the wire that was getting hot and just about caught fire was the right side wire. Too make a long story short, it was the high and low beam button that was damaged and was causing a short and needed to be replaced.
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #4 of 6 (permalink) Old Aug 27th, 09, 08:38 AM
red
Check out your key switch. My key switch burned up and caught fire once. check for loose terminal or coming apart key switch internals. shorting or grounding out
red67L78 is offline
post #5 of 6 (permalink) Old Aug 27th, 09, 11:06 AM
Dan
X2 on the keyswitch, I replaced original switch cause the key would come out in any postion and the brand new AC Delco switch had a dead short when in the start position and caused my 16Ga fusible link to smoke on the dash power-up wire at the horn relay. replaced and all is good now, also learned the importance of fusible link in engine compartment.
68 camaro RS 327/275 THM350 4 wheel disc brake 8.5 10 bolt 3.42 daily driver
icpop is offline
post #6 of 6 (permalink) Old Aug 27th, 09, 11:35 AM Thread Starter
Ron
Thanks everone for your input. As suggested by Jim in Mass [B]Sounds like your starter solenoid is frozen in the "ON" position or your starter is jammed, which caused a huge current draw." This was the problem. I pulled the starter and checked it out and on the bench it worked fine. I re-installed the starter and the car started with no problems and everything working properly. As Jim said the starter must have been jammed or the solinoid frozen. Thanks Jim
Viking11 is offline
