Adding a new Pertronix coil ? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 27th, 09, 09:01 AM Thread Starter
Lex
Lexlas's Avatar
Upgrading to a new high performance coil. Should the distributor also be upgraded at the same time ?
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Lexlas is offline
post #2 of 4 (permalink) Old Aug 27th, 09, 05:17 PM
Re: Adding a new Pertronix coil ?
Doesn't need to be. But upgrading is upgrading. You could upgrade the dizzy at the same time.
However, make sure you read the directions, some coils or distributors need another resistor.
400bird is offline
post #3 of 4 (permalink) Old Aug 27th, 09, 06:12 PM
Tom P's Avatar
You do not want to add a Pertronix Flame-thrower coil to your stock points type ignition system. If you also add the Pertronix distributor (with Ignitor II or III) you are OK.
As mentioned, read the directions, the Pertronix setup wants full 12V and eliminates the ballast resistor or resistance wire.
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #4 of 4 (permalink) Old Sep 2nd, 09, 11:27 AM Thread Starter
Lex
Lexlas's Avatar
Wow, glad i didn't make that mistake. Thanks
Lexlas is offline
