Relay attached to rear of speed/tach - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 30th, 09, 07:10 AM Thread Starter
Ron
I'm just finishing up with some wire restoration on a '67 RS/SS fact 4 gear with pwr windows. (it's incredible what can be done to a 42 year old car and its wire). I've got the windows working fine, however there is a relay that is attached to the back of the speedometer/tach housing that has me stumped. The harness/plug that connects to this relay has a WHITE WIRE that plugs into the relay and also gets connected to a post on top of the housing (I'm thinking ground), plus the harness/plug has an ORANGE WIRE that gets plugged into the relay, if you trace this ORANGE WIRE back it wyes to two plug connections which are not plugged into anything, and I don't see any 'empty' plugs. Finally, (IMO) there should be a third wire but sadly there is not. I'm thinking there should be GRD, IGNITION for the relay coil, and a larger gauge wire for LOAD, what ever the load is.
I've searched the threads for several hours but can't find the info I need, and I've poured over the wire diagrams but can't get the answer.
Thanks for your help, Ron
NUKER 67 is offline
post #2 of 3 (permalink) Old Aug 30th, 09, 11:49 AM
john
wagonman's Avatar
Re: Relay attached to rear of speed/tach
Maybe speed warning?
Remember,I'm not making this stuff up!
1969 rs/ss 396 350hp/4spd conv a/c,pw,ps,foldown
1968 Z/28 crossram- j/l8 conv pw,ps,foldown
1963 nova ss 350/4spd conv a/c,ps,pt
1963 nova 400 4dr 6cyl/700r4 a/c
2006 GT/5spd mustang conv
wagonman is offline
post #3 of 3 (permalink) Old Aug 30th, 09, 02:41 PM Thread Starter
Ron
John you nailed it. Thats what it is, I did a search for 'speed warning' and there it was, a picture of what I assumed was a relay.
Thanks to Ed (Bertfam) he had a picture on a previous post. Plus other posts confirm that the plug only has two wires, now to figure out how this gets wired, uhmmmm.........
Thanks again, Ron
NUKER 67 is offline
