voltage regulator - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 1st, 09, 07:49 PM Thread Starter
voltage regulator
On a 1970 there is a seperate voltage regulator that mounts on the firewall. With the rebuild I want to get rid of this one and put an alternator with a regulator in it. Is there a wire harness that can be purchsed for omit the regulator or do you have to rewire yourself. If I purchase a later model wire harness will it fit into the connector on the fire wall?
mhaseleu03 is offline
post #2 of 6 (permalink) Old Sep 4th, 09, 05:55 PM
Kev
Re: voltage regulator
There are 4 female spade connectors in the plug on the harness as I recall. I think you can jumper the two inner VR connector connections together and the two outer ones together to run a later alternator, but do some more checking, or rather don't trust me.
wiringharness.com should have a replacement harness that doesn't need any mods as well. There are other companies as well.
67sc is offline
post #3 of 6 (permalink) Old Sep 4th, 09, 07:29 PM
Originally Posted by 67sc View Post
I think you can jumper the two inner VR connector connections together and the two outer ones together to run a later alternator.
That is correct.
Also the 2 wire connector to the alternator is dofferent. with an external reg the alt connector looks like this || and with an internal it's --
I've seen kits that include an adapter for the alternator and a jumper plug for the reg. Not the cleanest setup wut better than home made.
post #4 of 6 (permalink) Old Sep 4th, 09, 10:00 PM
Larry
larryh56's Avatar
Check out Madelectrical.com. It will show you how to properly wire an internally regulated alternator and how to generally improve the underhood wiring system.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #5 of 6 (permalink) Old Sep 5th, 09, 04:41 AM
Harry
dawg's Avatar
american autowire has a harness to do just that.
434 stroker
US Navy retired
dawg is offline
post #6 of 6 (permalink) Old Sep 5th, 09, 08:47 AM Thread Starter
thanks for the info, this will help alot.
