Starter help - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 1st, 09, 10:22 PM Thread Starter
Starter help
Need some help here
I just finished installing my new motor and tko600.
I bolted the new starter up and wired it...
now when i activate the starter it just makes a small *bing* noise....like the stater is for a 153 tooth and the fly is a 168 tooth. sounds like it just smacks the plate.
The fly is however a 168 and the starter is made for a 168. It just wont interlock with the flywheel...
i don't hear anything turning or digging or anything of the sort. just a *bing* and nothing. (battery is full charge as well)
does shimming the starter down move the starter gear further away from the teeth on the flywheel?
sorry, i am totally lost
"Proform 67052 - Proform High-Compression Racing Starters" is the starter
67 Camaro
67speeda is offline
post #2 of 2 (permalink) Old Sep 1st, 09, 11:17 PM
Ken
Re: Starter help
From my experience you need to add shims until you can fit a paper clip between the starter gear and the flywheel. Mine was not far off without the shims
CamFrk68 is offline
