neg Battery Cable location - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 1st, 09, 11:39 PM Thread Starter
Ken
I am unsure where I should put the neg battery cable. I am using a customer alt bracket, aluminum heads and alum water pump. I am guessing it would go to the block, but was looking for suggestions as to where
CamFrk68 is offline
post #2 of 5 (permalink) Old Sep 2nd, 09, 12:42 AM
Steps
Re: neg Battery Cable location
I have mine on the bottom alternator mounting bolt...and have all the ground stapes from the engine to body and chassis.
Steptoe is offline
post #3 of 5 (permalink) Old Sep 2nd, 09, 04:23 AM
Camarodude67
Hi Ken,
I always place my battery cable on the engine block, lower passenger side and X2 with
the ground straps.
Jeff G.
68 Vert
69 RS/SS 396 Vert
69 RS/SS 454
camarodude67 is offline
post #4 of 5 (permalink) Old Sep 2nd, 09, 05:29 AM
Patrick
Originally Posted by camarodude67 View Post
Hi Ken,
the ground straps.
x3
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #5 of 5 (permalink) Old Sep 2nd, 09, 07:43 AM
The starter is the main current load. As long as the ground cable is connected to the block such that the starter can pull a few hundred amps through it without a voltage drop you'll be fine. As for ground straps, those are primarily noise suppression devices although they also provide a return path for the oil pressure and temp sensors that are grounded to the block. The main body ground is a pig tail lead from the battery (-) to the right fender just below the hood channel.
dnult is offline
