A list - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 2nd, 09, 07:05 AM Thread Starter
Elias
A list
Hi !
I'm acctually looking for some sort of "list" of all the things that need to be connected with wires or something similar.
Thanks !
E-
Camarofrom69 is offline
post #2 of 4 (permalink) Old Sep 2nd, 09, 07:15 AM
click's Avatar
Re: A list
Elias, maybe try a better description of what you need? Do you have the AIM for your car? Assembly Instruction Manual? It has wiring diagrams for every electric option, with color of wire, guage size of wire etc. perhaps that's what you want?
click is offline
post #3 of 4 (permalink) Old Sep 5th, 09, 06:25 AM Thread Starter
Elias
Re: A list
Hi !
First of all, one problem : I'm 14 so I don't have a Camaro = no AIM.. But is there a lot of wires that need to be connected ?
E-
post #4 of 4 (permalink) Old Sep 5th, 09, 06:36 AM
Andrew
Andrew69's Avatar
Re: A list
Yes, there are a lot of wires that need to be connected. When wiring my car (and I had never done this before) I found that in must cases the wiring harness is designed with plugs that will only plug into the component it was designed for. So it was mostly a matter of matching up plugs with components.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
