Is this a drain? - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 4th, 09, 07:33 PM Thread Starter
Is this a drain?
My cigarette lighter is wired it has power constantly. If nothing is plugged in while the car is off is there still a drain? Just curious. Thanks. Brian.
1969 original SS in family since 1971.350/330 crate w/ comp 270 roller cam,2004R,355 12 Bolt posi,P/S P/FTD Brakes P/W P/TOP Orig A/C car but removed.
Car nut is offline
post #2 of 4 (permalink) Old Sep 4th, 09, 07:58 PM
Re: Is this a drain?
Don't push it in and there is no drain.
post #3 of 4 (permalink) Old Sep 4th, 09, 11:18 PM
Steps
If you look at the fuse block..one side is live all the time...cig lighter, hazard lights, interior lights and a few other things.
The orange wire that goes to the cig lighter is live.
To find the drain, put a amp on the battery + to the battey +cable, then pull all the fuses one at a time...the confirm by putting them back one at a time.
Another issue is if the battery is dirty been painted or something like that...using the volt meter from the + put the - of the meter on the battery case, test areas getting closer and closer to the terminals.
Steptoe is offline
post #4 of 4 (permalink) Old Sep 5th, 09, 08:53 PM Thread Starter
The car stays on a battery tender so it is never dead. I just diddn't know if it was pulling power when off. Thank you both. Brian.
Car nut is offline
