windshield washer pump test in car? - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 8th, 09, 10:42 AM Thread Starter
Gordon
gordr's Avatar
Hi there,
I guess I should be able to test my non-working windshield washer pump while in the car.
It has juice at the yellow wire going in. So that means the blue wire would be ground. I simply put a grounding wire onto the blue wire little open exposed gap and that should make the pump work. But, it does not, meaning the pump is no good??
Thanks,
Gordon
gordr is offline
post #2 of 3 (permalink) Old Sep 11th, 09, 07:56 PM
Jeff
yellow69RS's Avatar
Re: windshield washer pump test in car?
Take the cover off and look at it to see if the pump is operating. If it's moving but not pumping fluid Trico makes a repair kit for the pump. The relay in there should energize when the ground is made and then the pump should pump until the gear makes a full turn.
Jeff
yellow69RS is offline
post #3 of 3 (permalink) Old Sep 11th, 09, 08:02 PM
Note also that the wipers always run while the pump is on. The motor controls both functions. Not like cars of today.
Melrose RS is offline
