how do you remove rubber well nuts from regulator - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 8th, 09, 08:15 PM Thread Starter
frank
I am frustrated. I think i need to change my VR, its the original one, cause i am having dead battery issues. Battery checked, ok and so did alternator. I bought a new VR and tried to remove the old one, is there a secret to removing these. I can easily get a 5/16 on the head of the bolt, but the front side just keeps spinning!!!
viper is offline
post #2 of 6 (permalink) Old Sep 8th, 09, 08:34 PM
click's Avatar
Re: how do you remove rubber well nuts from regulator
cut out the rubber edges with an exacto knife or other sharp object. They are just stuck in there.
click is offline
post #3 of 6 (permalink) Old Sep 8th, 09, 09:06 PM Thread Starter
frank
Thank you Jim
viper is offline
post #4 of 6 (permalink) Old Sep 9th, 09, 07:29 PM
Roger
rogerh's Avatar
Grab the nut on the grill side with a pliers and turn it out.
Roger
rogerh is online now
post #5 of 6 (permalink) Old Sep 15th, 09, 06:52 PM
Patrick
Is it OK if these units are grounded to the car or do you need to replace with rubber mounts?
1968 Convertible L92 VVT project, Hotchkiss lowering front & rear.
68problemchild is offline
post #6 of 6 (permalink) Old Sep 16th, 09, 07:40 AM
click's Avatar
either way as long as there is good ground contact. If you use rubber mounts, use pigtail ground wire up to the grounding tab.
click is offline
