1969 Camaro dash tach - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 9th, 09, 03:11 AM Thread Starter
I am going to install a factory tach in my wife's 69 350 camaro. The car did not come with a factory tach. The one I have has three wires coming from the tach. Light Blue, Yellow, and Orange. Also Could an x11 camaro have the 350 ss package. My wife's car has the same block as an ss only with a two barrell car. What special features did small block SS camaros have?
gab712 is offline
post #2 of 9 (permalink) Old Sep 9th, 09, 03:54 AM
Kevin
KevinW's Avatar
Re: 1969 Camaro dash tach
Gab, the SS350 added higher compression heads, 4 bbl and 4 bolt mains to the standard 350. You could get the style trim (X11) with any car. The tach was part of a gauge package, with a center clock and console gauges if you ordered a console, center fuel gauge if you did not and they could be ordered on any car too. Sorry, I dont know the wire colors.
Kevin
KevinW is offline
post #3 of 9 (permalink) Old Sep 9th, 09, 04:36 AM
The RPO Z21 Style Trim could be ordered on any car, as Kevin noted. X11 was the "catch all" X-code for cars ordered with Style Trim that were not SS396 (X22) or Z28 (X33) cars. So, all L6, base or optional V8, and SS350 cars ordered with Style Trim were coded as X11.
As far as the tach wiring goes, you may need to clear up what you're asking. Do you have some kind of aftermarket tach now, with the wiring colors you posted? A factory tach has/needs a 12V feed wire, a signal wire from the coil terminal, and a ground. I don't have the wiring diagrams handy this second, so I don't have the OE colors, but...
69 models equipped with a tach had a separate wiring harness for the tach, which went through the firewall adjacent to the fuse box/bulkhead connectors. Like this:
http://www.rickscamaros.com/product....dept%5Fid=3132
Eric
Eric Kammerer is offline
post #4 of 9 (permalink) Old Sep 9th, 09, 06:20 AM
madmax87's Avatar
Here is the info on a factory harness. See post #2
https://www.camaros.net/forums/showth...ht=tach+wiring
madmax87 is offline
post #5 of 9 (permalink) Old Sep 9th, 09, 07:36 AM Thread Starter
I didn't realize the factory tach was so easy to wire up with the use of Rick's wiring harness. Thanks. It is a factory tach from a 350 SS car. It has a portion of what I believe is the factory harness. This is where I got the colors from. and yes the heads have the small valves in them. The block is noted to be a 4 bolt main according to the stampings. My wife is a stickler to original equipment so she wants 69 camaro stuff, like clock and tach and what not. Thanks fellas.
gab712 is offline
post #6 of 9 (permalink) Old Sep 9th, 09, 08:32 AM
Kevin
KevinW's Avatar
Do you have the head casting numbers and dates?
Kevin
KevinW is offline
post #7 of 9 (permalink) Old Sep 9th, 09, 09:16 AM
Tory
Camaros-n-Chevelles's Avatar
Was the tach and gauge option listed on the cowl tag? My 68 has nothing on the cowl tag, but luckily I have the Protect-O-Plate.
Tory
1968 Camaro Coupe
1964 Malibu SS Unrestored 36,000 Mile Survivor
1964 Malibu SS Hardtop
1966 Chevelle SS 396
1968 Malibu L-79, 1 of 4082 ~ SOLD
1955 Chevrolet Bel Air Unrestored 15,000 Mile Survivor
1955 Chevrolet Nomad
1984 Hurst Olds with Factory Sunroof, 1 of 99 ~ SOLD
1992 Camaro 396 LS, 4L60, 9" Posi w /3.50:1 Gear Set
Camaros-n-Chevelles is offline
post #8 of 9 (permalink) Old Sep 10th, 09, 03:20 AM Thread Starter
Kevin, I have the casting number and dates listed somewhere in my files. I can't remember where. I know the production date of the car was 4/14/69. I'm almost positive the block is a 2388 (HD-350,250hp) and heads are 185 (c119) and not 186. I looked it up years ago and never revisited it. The car has 121,000 miles. The first two owners said nothing was ever done to the engine. also to the other member, the cowl tag states nothing for interior opitions that I am aware of????
gab712 is offline
post #9 of 9 (permalink) Old Sep 10th, 09, 04:22 AM
Kevin
KevinW's Avatar
Right, you have a L65 with a 2bbl carb, standard 350 offering.
Kevin
KevinW is offline
