Replacing ammeter with voltmeter - Team Camaro Tech
post #1 of 11 (permalink) Old Sep 10th, 09, 05:04 AM Thread Starter
I ordered a voltmeter from american auto wire to replace the factory ammeter in my console and it is a direct replacement so looks factory. I was just wondering if anyone else has installed one of these and how the wiring will be?
69huggero is offline
post #2 of 11 (permalink) Old Sep 10th, 09, 04:08 PM
Tom P's Avatar
Re: Replacing ammeter with voltmeter
Scott - I saw those also, they look like a nice piece. One thing that was not clear to me after watching the video - it sounded like the voltage gauge was primarily designed to replace the factory ammeter if you are running an upgraded or aftermarket wiring harness (higher output alt)
It didn't sound like it was plug and play for an OEM setup. I believe they are a sponsor so hopefully they will chime in
Tom P is offline
post #3 of 11 (permalink) Old Sep 10th, 09, 05:46 PM Thread Starter
Question Re: Replacing ammeter with voltmeter
I do have an aftermarket harness supplied by them (aaw) as I added the center console to my car along with guages, tach etc.. to make it a z-28 clone so hopefully it works well?????
post #4 of 11 (permalink) Old Sep 10th, 09, 05:57 PM
Tom P's Avatar
it should work out perfect - post some pics - I hope it can be wired up into a stock harness also.
Tom P is offline
post #5 of 11 (permalink) Old Sep 10th, 09, 06:59 PM
Thumbs up Re: Replacing ammeter with voltmeter
That's the holy grail! We've been wishing someone would produce an voltmeter replacement for the factory ammeter.
dnult is offline
post #6 of 11 (permalink) Old Sep 10th, 09, 07:11 PM Thread Starter
They released it the end of August
post #7 of 11 (permalink) Old Sep 10th, 09, 07:49 PM
I've been hoping someone would make this! Am I the only one with whit faced gages? The volt gage is brushed steel.
1968 Camaro - Original SS 396 4-speed, now a 427/550HP
1972 De Tomaso Pantera Pre L - 351 Cleveland 5-speed, 22,000 Miles
68427 is offline
post #8 of 11 (permalink) Old Sep 10th, 09, 07:57 PM Thread Starter
Mine are white faced also. I hope it is not brushd steel???????????????????
post #9 of 11 (permalink) Old Sep 10th, 09, 10:14 PM
Aaron
BigDawgDavao's Avatar
Anyone know if they are planning to come out with one for the 67?
BigDawgDavao is offline
post #10 of 11 (permalink) Old Sep 10th, 09, 10:35 PM
Voltmeter does not wire the same as an ammeter so it will not work with the factory harness. The guage was designed to be used with their Classic Update Kits. Ammeter goes inline positive side between the alternator and battery to read charge rate. Voltmeter can be placed most anywhere in the system as long as it is unfused (still needs to be switched) and needs one positive and one ground
Musclerodz is offline
post #11 of 11 (permalink) Old Sep 11th, 09, 01:14 PM
In addition to what MIke said above, the voltmeter should be getting power from an IGN source so the meter remains operational when cranking the engine. ACC power cuts off during the crank cycle.
dnult is offline
