TEMP GAUGE PROBLEM '69 LM-1 Camaro....HELP! - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 13th, 09, 09:41 AM Thread Starter
Casey
Question TEMP GAUGE PROBLEM '69 LM-1 Camaro....HELP!
Originally the car had idiot lights. I converted the steering column to a tilt and got rid of the idiot lights and went to a console. I've ordered all the correct wiring from Rick's and the restorer wired the console. Everything works except the temperature gauge. The temperature stays to the left of cold. So far I've changed 2 console temperature sending units, and installed 2 console gauges from Rick's. The problem is that when I turn the ignition on, the gauge moves LEFT of Cold and remains there. When I ground the green wire at the sending unit, it pegs the temp needle to Hot. There are 3 ground straps and also a body-to-gauge ground wire...it did nothing. Everything stays the same (left of Cold.) I also put a piece of cardboard in front of the radiator and ran the motor, but the needle only moved a tiny fraction toward Cold....nothing more. I'm pulling my hair out....PLEASE HELP!!!! Thanks, Casey
casey0272 is offline
post #2 of 8 (permalink) Old Sep 13th, 09, 09:48 AM
Re: TEMP GAUGE PROBLEM '69 LM-1 Camaro....HELP!
If one wire to the sending unit and grounding the green wire pegs the meter to hot, measure the resistance of the sending unit body to the block/head and back to the gauge return terminal, should be less than a couple of ohms.
Sending unit should decrease in ohm value as it heats up, from terminal to body.
Have a variable resistor, 0-5K or 0-1K? Substitute the sending unit to see if gauge works correctly.
post #3 of 8 (permalink) Old Sep 13th, 09, 10:32 AM
Did you use teflon tape on the sender, and are you sure the sender is a temperature sender and not the temperature switch that came with the idiot light.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #4 of 8 (permalink) Old Sep 13th, 09, 06:31 PM Thread Starter
Casey
Mark, We used teflon tape on the sender and I bought 2 sending units from Rick's Camaro. Thanks, Casey
post #5 of 8 (permalink) Old Sep 13th, 09, 07:32 PM
Joe
Smile Re: TEMP GAUGE PROBLEM '69 LM-1 Camaro....HELP!
Teflon tape can interupt the ground circuit. Try removing the tape and putting just a small amount of thread sealer on the top of the threads; leave the end of the threads clean to make a good ground.
That was my problem when I did the same install.
joe
Joe G
69 Coupe; ZZ430; TKO600; 3.55 posi; 13" Baer 4 wheel discs; 17" Billet Specialties wheels; Hotchkis/Koni rear; Ride Tech front; Classic AutoAir AC and power windows cuz I'm old and lazy!
Joe G is offline
post #6 of 8 (permalink) Old Sep 13th, 09, 08:19 PM
Jeff
yellow69RS's Avatar
Test the sender that is out of the block by testing resistance and then heating it up. If idiot light temp switch it will have almost zero resistance when hot. If gauge unit it will be the reverse.
Jeff
yellow69RS is offline
post #7 of 8 (permalink) Old Sep 14th, 09, 05:51 PM Thread Starter
Casey
I will try this week to take the teflon tape off this week and see if this works. I have check all ground straps.I will post later if this works. Thanks you all.
post #8 of 8 (permalink) Old Sep 15th, 09, 04:11 AM
Kevin
KevinW's Avatar
Casey, you DID replace your idiot light temp sensor with the one used for a gauge, right? they are different.
You should have took this one out:
Camaro Coolant Temperature Sending Unit, For Cars With Warning Lights, 1967-1969
Technically correct for appearance and connection type (pin) for 69 without factory console gauge option.
Item# CG-22
$18.99 ea.
And put this one in:
Camaro Coolant Temperature Sending Unit, Threaded Stud Connector, For Cars With Gauges, 1969
Technically correct for appearance and connection type (threaded) for 69 with factory console gauge option.
Item# CG-29
$27.99 ea.
Kevin
KevinW is offline
