Battery dead - or not - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 16th, 09, 06:20 PM Thread Starter
Okay, here's what I've got. 69Z pretty much all correct parts. The battery goes dead, so I thought. When I tried to charge it, my charger said "Bad Battery Connection". I clean and tighten everything, but get the same result. I take the wiring off the battery and then I can charge the battery fine. I reconnect the neg wire to the battery but not the pos and I can charge the battery fine. If I connect the pos wire, the charger reads "Bad Connection" again. I'm thinking I must have a short somewhere in the wiring, or a bad voltage reg, or a bad horn relay. Anybody have a place to begin?
kurt6325 is offline
post #2 of 6 (permalink) Old Sep 16th, 09, 09:56 PM
Steps
Re: Battery dead - or not
Many chargers if a battery is under 8 or 9 volts (depends on the brand) assumes the battery is a dud and will not charge
If you put another charged battery in parrell, then put the charger on, leave for a few minutes, remove the charged battery....u make the charger thing the battery is ok, and after a few minutes there is enough charge to continue to charge
To check if a battery is good..and dont have a carbon loader...purchase a battery hydrometer..doesnt mater if charged or 1/2 charged, check each cell and see if all cells read about the same...1 or 32 cells reading way diff indicated a dud cell.
I take the wiring off the battery and then I can charge the battery fine........
From here you description gets confusing, are u in the car? using the charger or alternator??
Do you have the +ve charger on the +ve bat terminal for charging?
Steptoe is offline
post #3 of 6 (permalink) Old Sep 17th, 09, 05:25 PM Thread Starter
Thanks for the info. I charged up the battery and reinstalled it and everything worked fine. Question now is why did the battery just go dead for no reason? I haven't taken the car out yet, so time will tell.
kurt6325 is offline
post #4 of 6 (permalink) Old Sep 17th, 09, 05:31 PM
I doubt the battery went dead for no reason, unless it had been sitting there for a year.
Most likely, something in the car is drawing some current.
post #5 of 6 (permalink) Old Sep 17th, 09, 06:30 PM Thread Starter
I agree, the battery shouldn't just go bad. It's not that old (last year) and I've had the car out a number of times this year. I did check to see if anything was left on, but couldn't find anything (I have left the lights on in the past, but not this time). I'm curious to see what happens this weekend when I take it out. Maybe I should through some jumper cables in.
kurt6325 is offline
post #6 of 6 (permalink) Old Sep 17th, 09, 10:38 PM
Steps
jumper cables went out with the arch...one of those portable battery packs are cool...run trouble lights off them, alsorts of stuff.
Steptoe is offline
