light switch bad? 69 camaro - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 17th, 09, 05:57 AM Thread Starter
Question light switch bad? 69 camaro
Gentlemen,
Been a while since i have had to ask a question of this group, however, before replacment thought i would ask. 69 SS 396 4 speed, center console guages (u17) full restoration. car is now running and i am trying to finish electrical. Two issues: 1. I was able to get all the front lights, etc. working, however, not one light works at rear (tail). My thought is that the switch is bad? 2. I noticed the ground wire connected to the tunnel at the center console was extremely HOT. in fact it began to burn into the plastic console. Fortunately, i noticed and shut it all down. Why did this happen? it seems like the ground is good.
Thanks in advance. I would like to get this resolved before the weather changes because i need to get some miles on the engine to break in.
Regards,
Doug
shelbydog is offline
post #2 of 3 (permalink) Old Sep 17th, 09, 06:34 AM
Kevin
KevinW's Avatar
Re: light switch bad? 69 camaro
Doug, just went through this. The taillight harness is only grounded by the black line that screws to the trunk latch support. If this ground is not good, then the return path finds another route by going back through bulbs until it finds a ground path. The most common path is through the instrument lights.
Check that ground well. I thought I had a good ground there, passed ohms check, put did not pass the amps going through it.
Your light switch is probably fine.
Kevin
KevinW is offline
post #3 of 3 (permalink) Old Sep 17th, 09, 08:33 AM Thread Starter
Thumbs up Re: light switch bad? 69 camaro
Thanks Kevin! I will give it another try.
