Converting vacuum RS to electric - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 17th, 09, 06:24 AM Thread Starter
Jeff
I am restoring a 68 conv SS/RS and i am converting the vacuum system to the new elec. door opening system. It told me to remove the overcenter springs for this system. I am still using the bellcrank support brackets but I am missing the bushings for the bellcrank so when I move the doors it is very wobbly and rubs against the bracket hole. Can someone tell me where I can get these bushings? Has anyone done this conversion? I am just in the process of doing the wiring with an all new harness kit from American. Very good kit but they should supply at least the light sockets pre-wired. Any help I can get would be appreciated.
Thanks,
JeffsSS
JeffsSS is offline
post #2 of 4 (permalink) Old Sep 17th, 09, 08:58 AM
Matt
Re: Converting vacuum RS to electric
You can get the bushings from just about all the after market part places like Classic, Rick's, Ground up. Also, check into the Retro-Electro RS Light Door kit. I and others have used it and we all love it. Here is a thread I put together on the install.
https://www.camaros.net/forums/showthread.php?t=164938
Matt
zlek131 is offline
post #3 of 4 (permalink) Old Sep 17th, 09, 09:09 AM Thread Starter
Jeff
Thanks Matt! I already purchased the system from Ground Up but they were unable to tell me what grommet kit to buy to get the correct parts. I had purchased a grommet kit from Rick's but it was only for the doors. I just purchased the kit from Ground Up because it has more pieces to it which I suspect will be the correct ones. This is a great forum and I am looking forward to following here and hopefully contributing.
Thanks again!
Jeff
JeffsSS is offline
post #4 of 4 (permalink) Old Sep 17th, 09, 09:21 AM
Matt
Yes this is a great site full of great people willing to share all kinds of priceless information. Keep us in the loop on the conversion and post any questions you may have.
Matt
zlek131 is offline
