Correct Battery and Cranking amps - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 18th, 09, 12:25 PM Thread Starter
Lifetime Gold Member
Drew
ddx77's Avatar
When looking for a battery for say my car 69 camaro with a BB in it, should I be looking for a minimum amount of cranking amps?
What is the correct way to shop for a new battery.
I did do a search for old posts but couldn't find anything
________________________________
1st Genless again - Working on getting my 69Z28 back.
ddx77 is offline
post #2 of 6 (permalink) Old Sep 18th, 09, 12:32 PM
Russ
Re: Correct Battery and Cranking amps
As for size, it's a group 24 battery and for cold cranking amps (cca) I'd say nothing less than 700.
My battery of choice for the last 10+ years has been the Optima spiral cell red top. Yeah they're expensive but they seem to last and they hold a charge even when the car isn't driven for months at a time.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #3 of 6 (permalink) Old Sep 18th, 09, 01:39 PM
Steps
Be carefull when buying a battery for older cars...make sure they are lead NOT calcium-calcium....The Ca batteries require a charge of about 14 to 14.2 volts, lead requires 13.8 to 14V
The Ca batteries never get a good charge, and die faster.
And if the US is like NZ, damn near all the guys behind the counter selling batteries dont even know this.
Steptoe is offline
post #4 of 6 (permalink) Old Sep 18th, 09, 03:31 PM
Originally Posted by rj68RS View Post
...My battery of choice for the last 10+ years has been the Optima spiral cell red top...
Same here and they don't puke acid all over your engine compartment like the wet cell batteries do.
dnult is offline
post #5 of 6 (permalink) Old Sep 18th, 09, 09:29 PM
Steps
The advantage the Optima has it is less prone to vibration than the lead acid....that is why orginally our cars had a foam pad under them...and if you do have one, is it still foamy, and not hard?
I have never in 40 odd yrs had a lead acid spue acid out...
I have seen ppl tip them over, over fill and other abuse and seen it happen...
Steptoe is offline
post #6 of 6 (permalink) Old Sep 20th, 09, 08:03 AM
Originally Posted by ddx77 View Post
What is the correct way to shop for a new battery. Thanks
First, look into the battery manf's catalog to see what size is suggested for a starting point. Owner's Manual states, by CID, 12 volts, 61 plates, 2900 watts, at 0F cranking.
I would go with a 650-750 CCA battery.
