69 coupe sb powerglide trans shifter backup light switch - Team Camaro Tech
post #1 of 10 (permalink) Old Sep 19th, 09, 02:33 PM Thread Starter
bigsteve
The backup lights on my car are not working. I opened up the shifter plate and all connections look goog. It doesn't look like there is any adjustment just 2 screws mount it forward and aft. So would it be safe to say if its not working it needs to be replace or is there a way to test it?
bigsteve is offline
post #2 of 10 (permalink) Old Sep 19th, 09, 03:32 PM
Re: 69 coupe sb powerglide trans shifter backup light switch
Well, the pink wire coming into the switch is the 12 V feed, so that is the first thing to check with key in run (or acc). If you have 12V, you can then connect a jumper wire between the pink and light green, then turn the key and see if the lights are on. If they come on, then the switch may be bad. If you have a multimeter, you can put it into "continuity" mode, hook to both switch terminals, and move the shifter back and forth and see if you get a tone.
Eric
Eric Kammerer is offline
post #3 of 10 (permalink) Old Sep 19th, 09, 04:04 PM Thread Starter
bigsteve
I have 12v at the pink wire.
Did the jump wire and had nothing at the light.
Used a multi metter on the switch and I did get a tone.
I also cecked the bulbs in another socket and they worked.
What would be the next step?
Also the pink wire goes to the rear of the swith and the green in front correct?
bigsteve is offline
post #4 of 10 (permalink) Old Sep 19th, 09, 07:15 PM
Jeff
yellow69RS's Avatar
Check to see that you have power thru the switch to the green wire then follow the green wire and see where it loses power. I would probably quickly check at the socket just to see if the socket is bad before tracing it all the way.
Jeff
yellow69RS is offline
post #5 of 10 (permalink) Old Sep 20th, 09, 07:33 AM Thread Starter
bigsteve
I plugged in the pink wire and tested for power at the switch where the green wire connets and it had power. I checked the connector (interior harness to tail light harness) and it has power. removed the bulbs from the sockets and they both had power with car in reverse and none in park. Can ant one tell me why the bulb sockets have power but the lights will not work?
bigsteve is offline
post #6 of 10 (permalink) Old Sep 20th, 09, 07:48 AM
Jeff
yellow69RS's Avatar
Poor ground, bad bulbs, bad sockets. in that order. IMHO
Jeff
post #7 of 10 (permalink) Old Sep 20th, 09, 08:41 AM Thread Starter
bigsteve
I have already cleaned the ground in the trunk the one that attaches to the trunk lock bracket, is there another I should look at. I have checked the old bulbs and tried now 1156 and nothing. Also if I'm getting 1v at the socket with out the car running with a v meter why wouldn't it light the back up bulbs when all the other tail light bulb are working?
bigsteve is offline
post #8 of 10 (permalink) Old Sep 20th, 09, 09:48 AM
Jeff
yellow69RS's Avatar
Steve, it sounds like you have elimnated two of the three in my post leaving bad sockets.
The sockets may not make contact with the bottom of the bulb or the side. If no contact on the side the ground is not complete thru the socket and if you put a test light to the basr of the bulb the test light will likely light and the bulb glow dim.
Jeff
post #9 of 10 (permalink) Old Sep 20th, 09, 09:59 AM Thread Starter
bigsteve
I just checked the ground in the trunk and it broke off the connector so I will repair that but I doubt thats the problem.
I put a test light to the dase of the socket and clipped the other end to the ground tab and had no light. I did the same thing to a working light and the test light lit up. I then ran the test light from the interior harness green wires to ground with the shifter in reverse and the light came on like it should. Also put test light from center socket and cliped it to harness ground bolt and nothing.
bigsteve is offline
post #10 of 10 (permalink) Old Sep 21st, 09, 02:46 PM Thread Starter
bigsteve
Now when I attached a ground wire from the side ground terminal on the socket to a metal ground screw in the trunk the light work. I take it the black wire going to the sockets are corroded or something and not giving a good ground?
bigsteve is offline
