forward ligth harness 1968 camaro - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 21st, 09, 06:59 PM Thread Starter
I am trying to replace my forward light harness, is there any trick to removing the wire end of the harness from the fire wall with a power buster? I loosened the bolt and pulled and pried,but it will not come off. 1968 camaro
Walotka350 is offline
post #2 of 4 (permalink) Old Sep 21st, 09, 08:27 PM
Re: forward ligth harness 1968 camaro
Just pull...
rusliding is offline
post #3 of 4 (permalink) Old Sep 22nd, 09, 03:48 PM Thread Starter
Getting at the plug is ending up to be very challenging, I have a power brakes booster in the way so it is very tough to get at the plug. Any tool that anyone would suggest to get in the tight space and work the plug loose? I really don't want to putz with the power brake booster.
post #4 of 4 (permalink) Old Sep 22nd, 09, 06:51 PM Thread Starter
Found my problem, the nut the in the fuse box was spinning so when I was turning the bolt in the harness end it was not loosing up. Once I could hold the nut and loosen the bolt the harness came right off!
