OEM Tach and Speedo to Autometer Gauge Wiring? - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 22nd, 09, 04:59 PM Thread Starter
Boo
Last March (2008) I added a tic toc tach to 68 and I have spent the past 18 months trying to figure out all its quirkiness. Anywho, I'm done with it. I'm going Autometer.
What do I need to change from a wiring standpoint? Can use the existing harness and PCB? I did some searching and couldn't find exact answers to these questions.
Thanks.
My Ride:
1968 Camaro SS Clone
booman55 is offline
post #2 of 3 (permalink) Old Sep 23rd, 09, 02:52 PM Thread Starter
Boo
Re: OEM Tach and Speedo to Autometer Gauge Wiring?
So nobody has done this?
My Ride:
booman55 is offline
post #3 of 3 (permalink) Old Sep 23rd, 09, 03:17 PM
Larry
larryh56's Avatar
I know it has been done, I found some posts a while back when I was contemplating the same thing. I decided to go with the tic-toc-tach and this is how I wired it if you decide to give that 1 more try:
https://www.camaros.net/forums/showthread.php?t=158264
You need a new circuit board for a tic-toc-tach if you didn't have a tach from the factory.
I would run new wires and leave the existing wiring in case you change your mind later. Just be careful to properly insulate and stow them so you don't get a short. The autometer gauges should be pretty easy to wire and should have instructions. The tach will need a circuit connected to your dash lights that will come on with the lights (white wire), the red wire goes to a switched source which you can take off your ignition switch or fuse block, black goes to a good ground and the green wire runs to the -ve side of your coil.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
