No GEN light - CS130 - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 26th, 09, 03:40 PM Thread Starter
Sean
I've just replaced my old CS130 with a new one.
(see https://www.camaros.net/forums/showthread.php?t=163940)
Now, I've installed it and the GEN light doesn't turn on in the ACC position. If I remove the connector and ground the "L" plug, the GEN light comes on. Any ideas? I've checked the grounds, and even tried adding a jumper from the (-) terminal on the batt to the case of the alternator. No help.
I just replaced the battery with an OPTIMA Red top. I get 12.68 volts at the battery when off. And 12.68 volts at the alternator. When I rev the engine, the voltage actually drops! to 12.30 (with no lights on, no electric fans.)
I use a 4 gauge wire from the Batt+ lug to the terminal on the starter where the battery is hooked up. The "L" conection goes to the brown wire which I pulled from the front wire harness and re-routed to the engine wire harness. The sensing wire is hooked up to a terminal above the horn relay.
68 Convertible | stockish 350 | 700r4 | 3rd Gen Power Steering | Dual Electric Fans | MSD Ignition | Island Teal
GR8_68 is offline
post #2 of 3 (permalink) Old Sep 27th, 09, 09:52 PM Thread Starter
Sean
Re: No GEN light - CS130
Well, I spent a fun hour at U-Pick-'em parts and grabbed a cs130 out of an Oldsmobile. I installed it and everything works just as it should. The Gen light comes on (not as brightly as when I just ground the "L" pin) and the system runs at about 14.2 volts with no headlights or fans at idle. Drops to about 12 at idle with fans and headlights at idle. Perks up to 13.5 at about 1800 RPMs.
So, I guess the new Powermaster alt is bad.
I drove it around for about half an hour and it seems like it's all solved.
GR8_68 is offline
post #3 of 3 (permalink) Old Sep 28th, 09, 03:42 AM
For giggles, I'd move the sense wire to the fusebox BAT spade.
Visit Harbour Freight and pick up a cheap, $5, ammeter and use it to see the alt output.
A CS130 should read 14 volts at idle with full load. My '88 Dually does, no reason yours shouldn't, I would think.
