Turn signal goes fast or slow - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 27th, 09, 01:37 PM Thread Starter
Patrick
Sometimes the turn signal has a fast flash, other times its slow. Perhaps the flasher selenoid(?) is grounding and un grounding? I notice it is not tied to anything under the dash but is hanging free.
Not sure.
1968 Convertible L92 VVT project, Hotchkiss lowering front & rear.
68problemchild is offline
post #2 of 8 (permalink) Old Sep 28th, 09, 11:00 AM
Mickey
Moonpie's Avatar
Re: Turn signal goes fast or slow
Try another solenoid.
Moonpie is offline
post #3 of 8 (permalink) Old Sep 28th, 09, 10:37 PM
Kev
Flashers aren't solenoids. They contain a bimetallic strip with a contact on one end and a fixed contact that the other touches. Thus, its a normally closed switch.
A bimetallic strip is two strips of dissimilar metals bonded together. When heated it bends.
When the turn signal switch is closed, current flows through the flasher, which heats the bimetallic strip, causing it to bend and cause the contacts not to touch. Then it cools and it bends back, causing the contacts to touch again. Blink. Repeat.
So if it flashes slow, current is lower. More current makes for a faster flash rate.
I'd look for bad/loose grounds.
Whew! That was long winded...
67sc is offline
post #4 of 8 (permalink) Old Sep 29th, 09, 11:40 AM
Mickey
Moonpie's Avatar
Oops, my mistake. Try another flasher unit,Patrick. That should show whats wrong real quick.I know that different flashers flash at different rates but no matter what rate they flash it should be constant. Perhaps the bimetallic switch has lost some of its temper or is even installed incorrectly inside the little can. If the new flasher unit does the same thing then you might have a slight electrical problem. More long-windedness on my part too. lol.
Whereabouts are you in North Texas 67sc ?
Moonpie is offline
post #5 of 8 (permalink) Old Sep 29th, 09, 05:14 PM
Kev
Try swapping the 4 way flasher with the turn signal one. I'd expect it to flash the hazards faster and the turn sigs slower due to the difference in current.
Does the speed vary while the car is sitting and turned off, running, moving down the road, etc.?
Are any of the flashing lights dimmer or more bright when it flashes fast or slow?
Is the difference when the parking or brake lights are on?
I'm in Grapevine...
67sc is offline
post #6 of 8 (permalink) Old Sep 29th, 09, 06:11 PM
Rappidly flashing signals is a sign of a short circuit. The current flow increases enough to cause the flasher to toggle on and off rapidly due to rapid heating of the bi-metal strip.
dnult is offline
post #7 of 8 (permalink) Old Oct 3rd, 09, 06:12 AM Thread Starter
Patrick
If this is a short, does the turn signal help me narrow down its location?
Where do I start?
Also, I have an MSD electronic tach wire running to the tach unit. Could this be putting electricity (backfilling) the circuits?
post #8 of 8 (permalink) Old Oct 3rd, 09, 06:27 AM
Hello,
I have a similar problem, but my turn signals only flash very rapidly.
Are some of the sending units fast and some slower?
Might it be a hazard flaser iinstalled in place of a turn signal flasher?
If a ground, where's the first place to look?
Thanks,
mgcvd is offline
