1969 Voltage regulator mounting - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 28th, 09, 07:02 PM Thread Starter
Doug
Hey guys should the voltage regulator on a 1969 Camaro be mounted directly to the fire wall with machine screws or use three rubber insulated speed nuts?
Was looking at this older post that showed this link. https://www.camaros.net/techref/elect..._regulator.htm
Anyone have a answer. Would be much help.
-Doug
Mr. Super Sport is offline
post #2 of 9 (permalink) Old Sep 28th, 09, 11:01 PM
parkbrau's Avatar
Re: 1969 Voltage regulator mounting
They are machine screws, i think 3/8. Mounted directly to fire wall.
parkbrau is offline
post #3 of 9 (permalink) Old Sep 29th, 09, 03:46 AM
If it is stock location, wouldn't the VR be on the radistor support vice firewall?
post #4 of 9 (permalink) Old Sep 29th, 09, 04:13 AM
Harry
dawg's Avatar
the firewall is not stock location?
434 stroker
US Navy retired
dawg is offline
post #5 of 9 (permalink) Old Sep 29th, 09, 04:38 AM
Kevin
KevinW's Avatar
The regulator mounts to the rad support above the horn relay. Depending on your build date will dictate what the mounting solution is. Sept 68 through sometime around Nov 68, use the rubber nuts, Jan 69 to end 3/8 hex head machine screws. Dec 68 is a toss up.
Kevin
KevinW is offline
post #6 of 9 (permalink) Old Sep 29th, 09, 05:17 AM Thread Starter
Doug
OMG I'm losing it! Meant to say radiator support. And what the heck is a radistor support?
Thanks guys for the help.
post #7 of 9 (permalink) Old Oct 3rd, 09, 09:01 AM
Jeff
I am doing the wiring on my 68 SS/RS. Does the voltage regulator have to be mounted with the rubber nuts or can I just use the hex head machine screws? Was there a specific reason for the rubber nuts? Does it have to be insulated for some reason?
JeffsSS is offline
post #8 of 9 (permalink) Old Oct 3rd, 09, 09:18 AM
OE design for 67 & 68 have rubber nuts and a strap from one bolt from VR chassis to radiAtor support.
I hard bolted my 68 VR using 1/4-20 bolts and nuts without the rubber nuts. Works fine.
post #9 of 9 (permalink) Old Oct 3rd, 09, 11:00 AM
Jeff
Thanks My 68 That is what I did also. Just wanted to make sure before I went hot with the wiring. Didn't want to ruin anything.
JeffsSS is offline
