!!!NEED HELP BAD!!! - 69 Camaro Wiring Gremlins - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 29th, 09, 01:02 PM Thread Starter
Hi All,
I bought a 69 from a guy that'd been scammed by a local Camaro guy...bad story. I got the car with new paint, motor, transmission, four goofed up tires...and the rest was gone or needed replaced. It'd been in storage for two years and was pretty dry.
As I did all of the work like interior, bumpers, glass, etc. all of the lights worked as I installed them with what appeared to be the exception of a few bad bulbs. Which were all new...but I know how fickle they can be so I kind of ignored them.
Anyway, as I was literally DONE with the car the blinkers stopped working and then a myriad of electrical bugs hit me and I am at my wits end and need your help!!!
So far I have a new battery with new cables that has been directly grounded to the engine block, sub-frame, and radiator support. The engine has been grounded to the firewall in two places and also grounded to the brake booster mounts from the back of the head. All grounds have been sanded clean and most have di-electric grease on them. I have thoroughly cleaned all connections on the voltage regulator, horn relay, harness to fuse block, the two grounds on either side of the engine compartment (by battery and horn relay) and have replaced all of the fuses. The rear tail-light harness is new and all others (that I know of) have been cleaned.
Most of the lights work as desired with the exception of the passenger parking lamp and the passenger rear blinker. The parking lamp does not work when the lights are on but works in all other conditions. The rear blinker/brake simply doesn't get bright for blinking or braking...but works in the dim setting.
All lights work properly when the hazzards are on with the exception of the passenger blinker/brake.
As I've worked on this a variety of the Tell-Tale lights and guage lights would either work, or not, and then often change. As it is now, the guage lights are the only lights not currently working.
I feel as if this is a bad ground or a short but simply cannot isolate the problem...can someone PLEASE offer me some advice!
Best,
-David Tittle
(972) 679-9861
1969 Z11 (yes, Z11) Pace Car with 15,772 un-restored original miles
1969 Z28 Clone
Dilusi is offline
post #2 of 4 (permalink) Old Sep 29th, 09, 01:54 PM
click's Avatar
Re: !!!NEED HELP BAD!!! - 69 Camaro Wiring Gremlins
David I gave you a few hints in CRG where you posted the same question. Hop over there for a looksee. welcome to Team Camaro too. Alot of us frequent both sites.
click is offline
post #3 of 4 (permalink) Old Sep 29th, 09, 05:13 PM Thread Starter
Well...after probably 60 hours of work on this issue...I found the problem(s).
First, grounds are uber important. If you ever have an issue like this...start with grounds and ensure they're good. You'll know as all lights that shine will be much brighter.
Next, there was a series of problems and I have cleaned EVERY connection on this car as well as grounded this thing to the hilt as well as adding a new rear light harness.
Finally, my actual issue is that the steering column wiring is bad!!! I found two fractured wires that appeared to be just from years of flexing. They still had two or three copper strands but were junk. I repaired them only to find the connection is really bad and loose. I cleaned it well and adjusted the small brass connectors to make them tighter by using a small screwdriver to scrunch them back into place and this has temporarily fixed my problems.
Looks like a new/rebuilt column and under dash harness for me. Sweet...just another thousand bucks!!!
Thanks for your help guys.
Best,
-David Tittle
Dilusi is offline
post #4 of 4 (permalink) Old Sep 29th, 09, 06:23 PM
This is a classic bad ground at the offending light. On a 69 it's most likely up front, the turn signal housing is not grounded.
