69 engine bay wiring - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 30th, 09, 01:50 AM Thread Starter
troy
thanks for all your help guys, i have more Qs though!! this car i have was put together nicely but with a lack of care, for details. its a gauge package SS396 car. with all new harness though out the car. but!!! i found already that he put the wrong engine side harness in without a tach feed wire.[dash harness does have corect wires'please see other Q posted about tach issues] with that said. what is the difference between the light side harness with gauges and with out, if any?? my amp gauges does not seem to work correctly??! rev the motor and it goes to discharge? let me know your thoughts thanks again for all your help
20round is offline
post #2 of 4 (permalink) Old Sep 30th, 09, 04:00 AM
Re: 69 engine bay wiring
69 models with tach have a separate harness on the engine side for the tach hookup. The Assembly Instruction Manual (AIM) shows where exactly the tach harness went through the firewall, to the driver side of the main fuse block bulkhead.
http://www.rickscamaros.com/product....dept%5Fid=3132
I belive the only difference for the 69 engine harness with gauges is that it would not have the wire for the oil pressure sender to warning light circuit.
I know there are two different light harnesses sold, but not sure of the difference. Pulled up the pics of each and it seems like all the same circuits. Wait, I looked at the better diagrams here on TC, and I see that the difference between the two is that the harness for warning lights uses one position on the bulkhead connector, while the harness for gauges uses one position above. So, if your engine side harness has a black wire going into the lower driver side corner of the connector, and the position immediately above that is open, then all you should need to do is move the wire to the open position above.
You can PM JimM for a password to get the more detailed PDF wiring drawings for 69, I think.
Eric
Eric Kammerer is offline
post #3 of 4 (permalink) Old Sep 30th, 09, 09:16 AM
Engine side harness for a guage car has the 2 leads in it for the ammeter, and single lead for the oil pressure gauge. Thats the only difference. Tach is a separate wire, and the temperature sender uses the same lead as the idiot light. The inner underdash harness routes it to the console instead of the dash.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #4 of 4 (permalink) Old Sep 30th, 09, 10:30 AM
Isn't the oil pressure gauge mechanical, and therefore there would be no need for a wire to the sending unit? Or do gauge cars have both the warning light and the mechanical gauge?
Eric
