Passenger Front Parking Lamp - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 30th, 09, 08:11 PM Thread Starter
Alan
HI Guys,
took my 69 out for a run tonight and noticed that the passenger front parking light was out. Turn signal flasher works fine. Came home, pulled the bulb, bulb tests good, socket (running light side) is dead (with test lamp).
According to the wiring diagram, power comes to the driver side parking light and then from there via a connecting wire goes to the passenger side. I am assuming that the issue is at the socket as the lamp had been working fine. My question is does the wiring plug into the parking lamp fixture via a plug?
thanks
alan
alanrw is offline
post #2 of 2 (permalink) Old Oct 1st, 09, 07:21 PM Thread Starter
Alan
Re: Passenger Front Parking Lamp
OK, corrosion in the connector which was to the outboard side of the battery. Removed battery,cleaned connection, dielectric grease, all is good again.
alan
alanrw is offline
