Should the small fuse be a SFE 4 - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 1st, 09, 02:09 PM Thread Starter
bigsteve
Would like to know if the small fuse at the bottom of my fuse box on my 69 Camaro coupe use a SFE 4 fuse. The function and size for the fuse has been wiped off over the years. So now I'm not sure what it calls for but that is the size in the holder.
Also why do some fuses have a thin wire and others have a thick flat piece of metal?
bigsteve is offline
post #2 of 7 (permalink) Old Oct 2nd, 09, 01:03 PM
Re: Should the small fuse be a SFE 4
That fuse is for the instrument lamps and it should be an SFE 4.
The amperage of the fuse determines the size of wire in the tube.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 7 (permalink) Old Oct 2nd, 09, 03:51 PM Thread Starter
bigsteve
Yeah, It broke when I removed it and now that I've replaced it with a new one the instrument lights dont work.
bigsteve is offline
post #4 of 7 (permalink) Old Oct 2nd, 09, 07:14 PM Thread Starter
bigsteve
Also does anyone make a SFE 10 or SFE 25 fuse and if not what size should I use?
bigsteve is offline
post #5 of 7 (permalink) Old Oct 2nd, 09, 07:53 PM
......have you checked the bulbs in the instrument panel to see if they are not blown????? Do you know if they worked previously????
David F.
468 CID 661 Horsepower
Turbo 400
33"x19.50" Mickey Thompsons
post #6 of 7 (permalink) Old Oct 16th, 09, 04:35 PM Thread Starter
bigsteve
Is there a way to test a glass fuse to see if its good, or how to test the terminal in the fuse box for power?
bigsteve is offline
post #7 of 7 (permalink) Old Oct 17th, 09, 01:24 PM Thread Starter
bigsteve
can anyone tell me how many grounds the dash lights have? Also what grounds the driver side dome light switch has?
bigsteve is offline
