20 amp tail light fuse melting - Team Camaro Tech
post #1 of 26 (permalink) Old Oct 2nd, 09, 03:53 PM Thread Starter
bigsteve
It looks like my 20 amp fuse for my tail lights is burnt and melting some solder. I would like to know what would be the cause of this?
bigsteve is offline
post #2 of 26 (permalink) Old Oct 2nd, 09, 04:24 PM
Re: 20 amp tail light fuse melting
Your dash lights don't work, also, you have a few problems, you have shorts or high restiance (sp). eaelier post you can't read the # for the fuse, if there is rust on the
fuse connectors can/will cause heat and a lot of other problems.
john68 is offline
post #3 of 26 (permalink) Old Oct 2nd, 09, 06:21 PM Thread Starter
bigsteve
Guess I need to sand them down more.
bigsteve is offline
post #4 of 26 (permalink) Old Feb 17th, 12, 03:19 PM Thread Starter
bigsteve
Whats the best way to remove the rust for the fuse terminals?
bigsteve is offline
post #5 of 26 (permalink) Old Feb 17th, 12, 04:37 PM
Kev
A short is extremely low. or no resistance, which is the opposite of high resistance. Fuses blow because of too much current, which comes from too low resistance.
Web search Ohm's law. As resistance increases, current decreases.
Rusty, or dirty contacts will make for more resistance, not less, and are not causing your fuse problem. That's not to say this isn't a problem, just not the stated problem.
There may be a connector on the firewall where the tail light harness goes through. If there is, disconnect it and see if the fuse still blows. If not, the problem is in the rear harness. If it does, the problem is under the dash.
67sc is offline
post #6 of 26 (permalink) Old Feb 18th, 12, 03:00 PM Thread Starter
bigsteve
I disconnected the tail light harness in the trunk and from what I can see the fuse is not melting. Is this a good indication that its time for a new tail light harness?
bigsteve is offline
post #7 of 26 (permalink) Old Feb 19th, 12, 07:20 AM Thread Starter
bigsteve
There may be a connector on the firewall where the tail light harness goes through. If there is, disconnect it and see if the fuse still blows. If not, the problem is in the rear harness. If it does, the problem is under the dash.[/QUOTE]
bigsteve is offline
post #8 of 26 (permalink) Old Feb 19th, 12, 07:36 AM
Not. if the harness is in good shape.
Since you've located the problem to the rear, puill one bulb and check fuse.
Fuse good, remove the one bulb and replace the other bulb.
Fuse blows, bad circuit or bulb - try the other bulb in the same socket.
Fuse blows, bad harness or single wire from the connector to the rear panel.
I would suspect a worn insulation spot from one of the sill cover screws.
post #9 of 26 (permalink) Old Feb 19th, 12, 12:57 PM Thread Starter
bigsteve
Harness is not in good shape. The reverse lights don't work without a separate ground wire attached and the right running light needs to have the wire moved around it the socket to get it working.
bigsteve is offline
post #10 of 26 (permalink) Old Feb 19th, 12, 01:04 PM
Fred
77thor's Avatar
Then I would buy a new harness.
77thor is offline
post #11 of 26 (permalink) Old Feb 19th, 12, 02:16 PM Thread Starter
bigsteve
thats what i'm thinking...from what I have read the American auto wire is the brand to buy
bigsteve is offline
post #12 of 26 (permalink) Old Feb 20th, 12, 11:39 AM
prostreet69camaro's Avatar
Yes it is.
prostreet69camaro is offline
post #13 of 26 (permalink) Old Feb 20th, 12, 02:51 PM
Hopefully, in your troubleshooting efforts, you exchanged a good set of bulbs, ie, the front ones, with the rear bulbs to eliminate a bulb problem and localized it to the wire harness.
Hate to see you spend the money for a new harness and still have the same problem.
post #14 of 26 (permalink) Old Feb 20th, 12, 02:55 PM Thread Starter
bigsteve
I've swaped all the bulb in the rear and the front directionals with new bulbs. I pulled the 2 reverse bulbs that have a bad ground and it looks like the new fuse ismelting again.
bigsteve is offline
post #15 of 26 (permalink) Old Feb 22nd, 12, 12:48 PM
The melted fuse is a problem at the fuse itself. Probably corrosion on the fuse terminals or perhaps the wiring or rivets on the back side of the fuse block is at fault. The corrosion creates resistance that limits the current to less than 10A (no blown fuse) but generates lots of head (melted fuse).
dnult is offline
