Speedo Thinks its a Tach! - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 4th, 09, 05:38 AM Thread Starter
Jeff
68IslTeal's Avatar
Something is wrong, but I cant seem to narrow it down.
I just redid the wiring of my 68 camaro with an AAW kit, and for some reason the speedo bounces and moves when the tach moves. This is a stock speedo/guage cluster and a autometer tach.
Has this happened to anyone else, and or does anyone have any ideas?
I have had the under dash section of the wiring kit out 2 times to check the wiring connections etc... and all are as diagramed.
68IslTeal is offline
post #2 of 5 (permalink) Old Oct 5th, 09, 04:14 PM
Re: Speedo Thinks its a Tach!
Well the speedo is mechanical and not controlled electronically (like the tach) so I don't see how engine RPM would effect what the speedometer does...
But, if your speedo is bouncing you could try lubing the cable. Search to see how its done, cause I have no idea.
400bird is offline
post #3 of 5 (permalink) Old Oct 5th, 09, 04:19 PM
X2 on the lube job.
Try a new cable with lots of grease on the cable and you want to pack wheel bearing grease on the gear according to the manufactures.
Blown budget is offline
post #4 of 5 (permalink) Old Oct 6th, 09, 05:32 AM Thread Starter
Jeff
68IslTeal's Avatar
/blush
DOH! You will get a kick out of this one....
all I need to say to preface this situation is "my driveshaft is not installed".
Yeah the transmission was in gear so turns out no problem after all.
post #5 of 5 (permalink) Old Oct 6th, 09, 10:31 AM
Ha, good save.
400bird is offline
