SFE 10 & 25 fuse - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 4th, 09, 04:35 PM Thread Starter
bigsteve
SFE 10 & 25 fuse
Anyone know who sells a SFE 10 & SFE 25 fuse?
bigsteve is offline
post #2 of 4 (permalink) Old Oct 5th, 09, 02:02 PM
Re: SFE 10 & 25 fuse
If you want to replace your SFE 4 fuse with a higher amperage there's a problem with the SFE series. They get longer as the amperage rating increases. The AGA series fuse is the same size as the SFE 4 and is available in 1, 2, 3, 5, 10, 15, 20,and 30 amps.
Be careful because this fuse protects the dash dimmer on the headlight switch. If you have a short somewhere and put in a fuse with an amperage rating too high you could smoke the dimmer. Instrument lamp wires are usually gray 18 gauge and there's one in the radio harness which gets cut off quite often.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 4 (permalink) Old Oct 5th, 09, 03:57 PM Thread Starter
bigsteve
no, I'm keepingt that one SFE 4. I'm looking for a SFE 10 and 25 to replace the AGC 10 and 25 that I'm using now in to other spots.
bigsteve is offline
post #4 of 4 (permalink) Old Oct 6th, 09, 12:52 PM
SFE fuses are only available in 4, 6, 7.5, 9, 14, 20 and 30 amps. The AGC fuses will work fine everywhere but the instrument lamps.
12run is offline
