Wiper wiring ? - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 5th, 09, 04:00 AM Thread Starter
Jeff
Wiper wiring ?
My wiper has 2 plugs on it each with 2 wires. Yet the wiper itself has only 3 terminals on it. I dont have a washer so maybe thats part of the problem but seems the washer wires are seperate anyway. So the way it is now one of the wires on the bottom plug just hangs in the air and has no terminal in it. Whats up with that??
Also it seems the 2 connectors can be swapped with each other and also flipped over so im confused as to which connector belongs on top and which on the bottom and which direction each one goes. Basically the wire colors from top to bottom would be helpful. thanks!
jeffs68camaro is offline
post #2 of 8 (permalink) Old Oct 5th, 09, 05:33 AM
parkbrau's Avatar
Re: Wiper wiring ?
jeff i sent you an email at the stang8s address. it has a schematic you might use.
parkbrau is offline
post #3 of 8 (permalink) Old Oct 5th, 09, 05:45 AM Thread Starter
Jeff
Re: Wiper wiring ?
Thanks for the drawings.. I have a bunch of them but find them hard to follow when trying to match to connectors on things.
post #4 of 8 (permalink) Old Oct 5th, 09, 05:57 AM
parkbrau's Avatar
Re: Wiper wiring ?
I'm at work. If you want i'll tale a few pics of my 69 wiper motor connections and post them when i get home in an hour or 2
parkbrau is offline
post #5 of 8 (permalink) Old Oct 5th, 09, 07:49 AM Thread Starter
Jeff
Re: Wiper wiring ?
cool! That would be a big help. thanks
post #6 of 8 (permalink) Old Oct 5th, 09, 09:04 AM
parkbrau's Avatar
Re: Wiper wiring ?
Heres a pic of my 69 wiper connections. I put the white piece of paper in there to help you see it better.
parkbrau is offline
post #7 of 8 (permalink) Old Oct 5th, 09, 09:06 AM
parkbrau's Avatar
Re: Wiper wiring ?
And another
parkbrau is offline
post #8 of 8 (permalink) Old Oct 5th, 09, 09:32 AM Thread Starter
Jeff
Re: Wiper wiring ?
hmmm. i think the problem is that im missing the washer pump.. mine is totally different looking! Thanks
