Engine Harness Wire Ident Help - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 5th, 09, 09:34 AM Thread Starter
frank
I am piecing together my wiring and I have a question for anyone in the know. My original engine wiring harness has a meshed wire and a yellow wire that are crimped to a heavier guaged a faded red wire that goes into a connector.
In this connector there is a black wire not being used that has fusible link stamped on it.
This connector receives a knife connector. Right now a red wire smaller guage wire from my msd is tied into this connector.
The new harness I have installed has this meshed wire and yellow wire do I tie into this connector with new harness. The car came with msd so I do not know if the install was done correctly!
jet mech is offline
post #2 of 7 (permalink) Old Oct 5th, 09, 03:15 PM
Re: Engine Harness Wire Ident Help
Could be the two wires, yellow - from R teminal on solenoid- and meshed wire - resistive wire from firewall connector being ignition power, tied together to supply ign 'ON' signal to MSD box and would be normal for MSD install.
Picture would be good.
post #3 of 7 (permalink) Old Oct 5th, 09, 03:54 PM Thread Starter
frank
Do I need to buy a jumper so that my meshed wire and solenoid wire(yellow) from firewall can tie into msd? Sorry if this seems like silly question. My meshed and yellow wire are tied together with a horseshoe shaped connector on end??
jet mech is offline
post #4 of 7 (permalink) Old Oct 5th, 09, 05:32 PM
Horseshoe terminal, sideways I might add, is OE design. Hook them both up to the MSD, according to the instructions of the MSD box or from their website.
post #5 of 7 (permalink) Old Oct 6th, 09, 06:47 PM Thread Starter
frank
Thanks again Everett
jet mech is offline
post #6 of 7 (permalink) Old Oct 7th, 09, 03:09 AM
You're welcome. Does it work?
post #7 of 7 (permalink) Old Oct 7th, 09, 07:00 AM Thread Starter
frank
Everett I think i have just completed all the wiring. I will be installing engine this weekend. The Msd tech told me as you did, cut horseshoe off which had cloth wire that was ganged with yellow wire buy a spade an tie it in to msd. This is the on signal to msd!!
jet mech is offline
