67 RS headlight doors and lights not working correctly - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 10th, 09, 11:46 AM Thread Starter
1967 RS electric headlight doors
As soon as the key is turned, the driver headlight door opens. This is with the headlight switch turned off. Turning on/off the headlight switch has no effect on the doors or lights.
New headlight switch? Seems like something must be shorting somewhere, but I'm not sure where to start troubleshooting.
Thanks, Scott
His and Hers Marina blue 67's
67FamilyFun is offline
post #2 of 2 (permalink) Old Oct 10th, 09, 07:32 PM
Re: 67 RS headlight doors and lights not working correctly
Check to see if your relays have the correct connections. This website will get you started. http://www.retro-electro.net/FAQ.html It's excellent for troubleshooting. Good luck!
Melrose RS is offline
