No Turn Signals -- HELP! - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 11th, 09, 05:25 PM Thread Starter
I replaced my front headlight harness on my 1968 Camaro. When completed my turn signals both in the dash and the outside of the car do not work. My 4-ways work. I checked the fuse box and all seems ok. Then I replaced my flasher can and still no success. Does anyone have an idea? Could it be the the turn signal switch in the column? Or could something have come loose in the fuse box?
Walotka350 is offline
post #2 of 5 (permalink) Old Oct 11th, 09, 08:11 PM
steve
Re: No Turn Signals -- HELP!
check the fuse to fuse holder connections in the fusebox . if there's a bad connection there they won't work. if using a test light make sure that you check for power on both ends of the fuse holders (not the fuse)to ensure that power is going through the fuse and fuse holders.
grampstoyz is offline
post #3 of 5 (permalink) Old Oct 12th, 09, 03:08 AM
Purple wire from the fusebox to flasher and purple from flasher to steering column connector.
post #4 of 5 (permalink) Old Oct 12th, 09, 06:01 AM
NHBandit's Avatar
First question is did they work before you changed the front harness ? If so then I can't imagine why you would think it's a bad switch. Maybe the switch got mad that the wiring was getting all the attention ? If the wiring is all you messed with and they worked before logic tells me it's something in the wiring...
NHBandit is offline
post #5 of 5 (permalink) Old Oct 17th, 09, 05:25 PM Thread Starter
I checked for power between the two halves of the fuse box -- power was going in but not out, but the fuse was good so I made sure the wire was plugged in. I removed the fuse and cleaned the clips or fuse mounts, reinstalled the fuse, and then the turn signals started to work. Thanks for the help.
