69 camaro ignition question - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 12th, 09, 06:19 AM Thread Starter
when i turn my key off the car continues to run. Is this a bad ignition switch or what else could it be? it is a non-tilt column
2005 2500hd, duramax,crew cab, 4x4,
2012 GMC Terrain awd
1981 Bandit Trans Am(LS1)
2007 Z06 Corvette
2004 R1 (stock)
2005 Grizzly
2005 Z71 Suburban
1969 Camaro SS 496 stroker, 4sp ( in body shop)
camarossrulz is offline
post #2 of 7 (permalink) Old Oct 12th, 09, 06:29 AM
Re: 69 camaro ignition question
Ign switch, the electrical portion on the column, may need adjusting, if car is stock configuration.
If an aftermarket ignition system or internal regulated alternator has been added, then it probably needs a diode added to prevent run-on after key is turned off.
Mad Electrical and MSD have instructions/illusrations concerning this event.
post #3 of 7 (permalink) Old Oct 12th, 09, 06:30 AM Thread Starter
I did add a msd, i will check into it. thanks
2007 Z06 Corvette
2004 R1 (stock)
2005 Grizzly
2005 Z71 Suburban
post #4 of 7 (permalink) Old Oct 12th, 09, 06:47 AM Thread Starter
I had someone install it for me so I do not have the diode that was supposed to come with it. does anyone have on that they dont need or know where I can get one? I will try to call msd to see if I can get one from them.
2007 Z06 Corvette
2004 R1 (stock)
2005 Grizzly
2005 Z71 Suburban
post #5 of 7 (permalink) Old Oct 13th, 09, 01:30 PM
Wes
By continuing to run, you don't mean 'dieseling' do you?
Straight-line-69 is offline
post #6 of 7 (permalink) Old Oct 14th, 09, 08:52 AM Thread Starter
no it runs when you take the key out just as if the key was in and on. I got the diode yesterday but im still a little un sure how to install it. does anyone have a pic of one installed?
2007 Z06 Corvette
2004 R1 (stock)
2005 Grizzly
2005 Z71 Suburban
post #7 of 7 (permalink) Old Oct 14th, 09, 02:44 PM
Here ya go:
http://www.msdignition.com/page.aspx?id=3296
